New WoodChat!
Shaker Nightstand Project (Long)
Todd Nebel
I hesitate to post this today with all the creativity going on here today (April Fool's Day), but I know I won't get around to posting it over the weekend.
My youngest daughter finally came around and asked for a piece of furniture for her bedroom. She is almost 12 and watched her older sisters get piece after piece until I made most all their bedroom furniture, but never asked and when I suggested she just said no thanks. You can imagine my pleasure when she asked for this piece.
I found a somewhat local lumber supplier and bought her requested wood - maple. This was average for their stock on hand.
I used only a third of the 8/4 stock for the legs, a third of the common stock for the drawer sides and bottom, only enough for the drawer fronts on the narrower curly, and most of the wider curly/quilted on the top, sides and back. So, all in all, about half the cost listed.
Getting to this point was real quick. The top rail is dovetailed into the legs. I got to use the Blue Spruce mallet again. Really like that tool.
I was enjoying my progress and all was going well after a full Saturday in the shop; I'm then lying in bed thinking about the work done and what's next, and it hits me... that awful feeling. Yep, I put on the slippers and headed to the basement and dry assembled it again... I cut the tapers on the wrong sides of the legs :(
Well the only thing to do now is taper all four sides. Not, my preferred design or "correct", but I think I can get away with it. The camera lens tends to distort it more than if you are standing in front of the table.
The top, sides and back look amazing as you walk around it. Not that you will be able to after it's in her bedroom. I'm not even allowed in there unless I request permission.
So, here's the finished table.
I turned the knobs on the lathe and used CA glue like I do on pens.
The drawers are handcut half-blind in the front and through in the back. The bottom sits in stop dados.
The finishing process... sand to 600 grit. Mixwax Wipe-On Poly high gloss, 6 coats, 600 grit between coats. Thanks for looking and reading.
BTW... She absolutely loves it!
Re: Shaker Nightstand Project (Long)
The hits just keep on coming!
You do lovely work, Todd - really classic lines and proportions. The wood is lovely!
And worry not about not being allowed in the room - after teenagers move out, it takes very little time to fumigate the room.
David Barnett
Beautiful work. Beautiful wood.
David Barnett
Your daughter has great taste in furniture and wood both, and really knows how to one-up the older siblings, I'm betting. That piece is a jewel.
Pam Niedermayer - Austin, TX
As well she should, good eyes and all that. Excellent piece of work, Todd.
Pam
Re:Maple side table
George in almost spring Lowell, Mich.
Todd
Wow!! That baby looks great! Now you will have to make it's mate or was this a "one of"?
Was it easy to tell the figured wood even in the rough state?
Inquiring minds also want to know. What is the reference to CA glue mean??
Work safe
George
Re:Maple side table
Todd Nebel
Hi George,
This was a one of piece.
The lumber suppier planes one side of the figured stock so he can grade it and charge more :(
The reference to CA glue - pen turners use instant glue as a finish. You put a little on a piece of paper towel or directly on the wood while spinning on the lathe, working quickly. Then spray it with accelerator and repeat often. Build up a nice hard plastic finish and then sand it with micro pads and buff with compound. The result is a super high gloss and durable finish. The benefit is that it's super quick and you can get a very even coat.
Thanks,
Todd
maybe the last piece...
Todd Nebel
... for until fall. Once trout season starts and the weather is nice enough to ride the Harley, my interest turns away from the shop.
Beautiful work Todd. Your daughter has good taste.
Your save on the legs would only be apparent to us because you mentioned that it was a save. It does not look like a save - the tapers look like they belong there. I like them as they are!
That's another great looking table....
roger lance
and nice Rainbow !!....so get your motor runnin and head out on the highway....later.
