New WoodChat!
Is a froe a froe?
Is a froe a froe?
Is a froe a froe?
Ben Ragusa
Or is one better than another? Their prices range from a low of about $40, to $150 or so. The reason I'm asking is that tomorrow a large oak will be removed from my property, and inspired as I am by a joiners' blog, I'd like to try my hand at riving a few boards for some simple boxes, and I need a froe.
Re: Is a froe a froe?
TomD
No, like anything else there are differences. The main things to be on the lookout for are froes designed to pop shingles from very easily split wood, tend to have high angle entry. Froes that go in easy, and twist easy, and froes for stuff like ash baskets. None of the froes I have are all that well made. None are hardened, I have bent some. I like the Country workshops ones. They are just some 1020 , or some such ground to an airplane wing shape, and with a tube welded to them. And easy project if you have a buzz box. I did bend one, so I would probably make the next one, not because they don't deserve the business, but because if it is going to look like something I made anyway, I might has well have...
Lee Valley used to have a good one, the handle wasn't as nice, but that part is replaceable, and it didn't knife in , or cam as nicely, but it was a good one. I don't currently see it in the catalog which is odd. They used to have one I didn't like, so be careful. With CW you can sometimes get them to sell them to you unhandeled
Jack Guzman from Maine
I can't see spending $150 on a froe. All you need is a rigid piece of steel with a handle on it. You can grind any angle you want on it. Basically its only a prying tool. I split with an ax or wedges. With a froe you can direct the split somewhat.---Jack
Larry Barrett
ditto the above, and before you get close to using a froe you will need steel wedges, a sledge hammer, and gluts to work your large oak down to eighths or maybe sixteenths. You really can do most of what you want with wedges.
Bob Hackett
Drew Langsner`s books have some really good info that will be of help to you.He covers everything from selecting and felling the tree to making the projects.
With the right type of wood green woodworking can be a very addictive process. Drew shows you how to make the tools you need so you get to pay for them in sweat rather than cash. :D
Jim DeLaney, Austintown, Ohio
Re: Is a froe a froe? - Make your own
Go to a junkyard and get the main leaf from a car spring - the one with the loop on each end.
Using an abrasive wheel in an angle grinder, cut the spring leaf to the length you need the froe to be (one leaf will make two froes).
Use the angle grinder to sharpen one edge of the froe (leaf). It doesn't need to be very sharp; just sorta take the rounded edge off.
Use a dowel, part of a broken axe handle, or just a piece of branch for a handle.
An hour's work; maybe five bucks invested; and you've got two froes.
Rob Lee
Hi Tom -
We actually do have a froe again - the web page is just hidden, until we can get stock to all stores....
http://www.leevalley.com/US/wood/page.aspx?p=67231&cat=51&ap=1
We also put up a froe mallet today - check the new product area...
Cheers -
Rob
Jim Crammond
Ben,
I agree 100% with Larry, before you reach a point where a froe will be useful, you will have to split the log into halves, quarters, eighths, sixteenths and possibly more, depending on the diameter of the tree. This will take a sledghammer and several wedges. The bark side of the split will have to be down to 3" to 4" before the froe becomes an effective tool.
Also, keep in mind that you always have to split the piece in half, if you don't there will be problems with run out and a lot of usable wood will be lost.
Stephen Shepherd
Make your Gluts from sycamore branches
Stephen Shepherd
TomD
Thanks Rob. That hidden web page reminds me of Doctor Strangelove. :)
"Of course, the whole point of a Doomsday Machine is lost, if you *keep* it a *secret*! Why didn't you tell the world, EH? "
That looks basically like the one you have been selling for quite a while? It seems like the one I have. It has a nice convex entry. I like it.
Thanks for your advice
Ben Ragusa
Thank you all for your advice. I have read Langsner's books, and I have a bunch of wedges and gluts. I'm gonna need them. The pieces I have are about 30" in diameter. I plan to reduce them down to size with chainsaw, then wedges and gluts, and finally the froe. Most likely a good one from Lee Valley.
Re: Thanks for your advice
TomD
I don't know if anyone else has had this experience, but I found I needed to have either a wooden glut to pound in the metal wedges, or a wedges with wood on them and a steel mallet. Steel on steel doesn't work for me.
Stephen Shepherd
Terminology question
Stephen Shepherd
'I don't know if anyone else has had this experience, but I found I needed to have either a wooden glut to pound in the metal wedges, or a wedges with wood on them and a steel mallet. Steel on steel doesn't work for me.'
Do you mean wooden mallet? A glut is a wooden wedge, the best are made of sycamore branches because the wood compresses a bit, holds well and doesn't easily split.
I use a wooden froe maul for my large and small froes. I use a wooden mallet for my small basket froe. I also pound my iron wedges with wood, never metal. Wood on metal transferes the force to the metal better than metal on metal because it doesn't bounce back.
Stephen
What are "gluts?"
Pam Niedermayer - Austin, TX
Re: What are "gluts?"
Bob Hackett
There are a round bodied wooden wedge only bigger than your garden variety splitting wedge,at least mine are.The ones I make are hooped at the top with a slice of pipe.
Got it, thanks.
OK Jim, let's say I got ones layin in my...
Scott Burr in Ben Lomond CA
Front yard. Howd ya all go 'bout disbeselembing them with out 'em comin' part and slapin' you likein your wife when you come home drunk and smellin' like the barmaid?
If I might ask, whats a glut?
All I know is that most of are NOT in one... :b
I should rephrase that. Gluts can be good or bad, so that as you will.
Re: Terminology question
TomD
Yeah, I am thinkin wackin stick.
Stephen Shepherd
Re: If I might ask, whats a glut?
Stephen Shepherd
It does have several meanings but the reference here is to wooden wedges called 'gluts' and the best are made or round sycamore branches as the wood compresses and holds in the wood.
It can also mean in the spring time when the water is high and the logs get jammed in the river, that is called a 'glut'.
Stephen
Dealing with distractions
Bob Hackett
First thing you do after leaving the bar is drive to the site and remove the leaf springs from your trunk is get the barmaid to climb down off of you and sit on the stump left over from cutting the tree. Now that you can think a little more clearly just measure from the eye to the end of the potential froe (I rarely go more than 18 inches total) and strike a line.Resist the urge to have the barmaid hold the end of the tape or anything else for that matter.I find it works best if I put on my frown face,point to the stump and bark "SIT" in a stern voice.
Now take your grinder with the cut-off wheel and fire up the generator,plug in the grinder then cut on the line till the end with the eye falls off.If the barmaid tries to help again spray some sparks her way but try not to get any on the jacket you loaned her.That`ll just make holes in the fabric and let the wind thru when you`re out hunting.
Change wheels on the grinder and grind the bevel on the potential froe blade.Get the barmaid to move over to the car (remove the keys first) so you can use the stump for a bench.Hold the potential froe with your foot and avoid the complications inherent with having the barmaid help by holding anything,you know what the smell of cheap perfume does to your thought processes.
Once you have your potential froe properly ground down take your bowsaw in one hand and the PF (potential froe) in the other(wait till i`s cooled from grinding,have another beer while you`re waiting) and look at the branches you previously trimmed earlier in the day before you picked up the barmaid till you find one that is just a little bit bigger than the eye of the PF.No no,not that one,that`s too big,put that down and look again.
Now trim the bark off of the branch end with the PF and then use the back of the bowsaw to drive the PF onto the branch stub.Turn the bowsaw over and cut the branch to the proper length for the handle.OK,too short,drive the PF off with the back of the bowsaw and start over with a new branch.
Once you get it together and have successfully assembled everything congratulate yourself your PF is now an RF (Real Froe).
Take your RF back to the car,wake the barmaid up and get her to slide over so you can drive.
IMPORTANT TIP- remember to drop the barmaid off BEFORE you drive home to wake the wife up and show her the froe you just made.Even if your house comes before the drop off point the time you save will not be worth all the shouting ,ducking and shooting involved.All real froe makers know this,don`t be act like an amateur here.Besides the soon to be ex-wife will not be able to fully appreciate your new froe in such a stressful state,the barmaid`s screaming is just too distracting.
While the pull of immediate gratification is strong drive past the house and drop the barmaid off first.Trust me it`ll pay dividends in the long run.One must think beyond their own ego from time to time in order to maintain matrimonial bliss.
Oh yeah,remember to take the back roads while driving.You don`t want another OUI do you?
Glad To be of service to all potential woodsmen out there. :)
Re: OK Jim, let's say I got ones layin in my...
Front yard, eh? Gee, a true Redneck!!! :D :D :D
Leaf springs come apart easily. They don't "sproing" about like coils do. Most have a center bolt (usually firmly rusted in place) and several metal clips, or wraps that keep the leaves in place. The wraps/clips usually just slide off, but you can cut them if you need to. Actually, you wont even need to disassemble the spring - just cut the main leaf and the piece you need will come right off.
Bob's directions are quite good, actually. Do be careful with that barmaid, though. She could get dangerous... 8)
Ben Ragusa
Well, I had at for a few hours with just the wedges and gluts, and managed to split out some stuff. Not a lot, but it's a start. The best I could do in terms of thickness resulted in wedge shaped pieces, about 10" wide, and about 1.5" on the wide side, tapering down to about 1". My attempts to split any thinner were not successful, as the split would not stay in the middle. It tended to run out toward the face. I guess that's where the froe would be useful; in starting the split across the full width of the piece as opposed to a wedge, which starts the split in one spot. At any rate, this is hard work. The first splits are the hardest. As the pieces get smaller, it gets easier, but then controlling the direction of the split becomes an issue. My hands are sore.
Re: If I remember correctly St. Roy...
George in not so snowy Lowell, Mich.
had a way to "steer" the froe through the wood to keep the slice consistent in thickness. Hopefully someone else remembers how to "steer" one of these.
Work safe,
George
Re: If I remember correctly St. Roy... *LINK*
Larry Barrett
Pete Galbert has a lot of useful info on his blog. Take a look through this link to his posts on greenwoodworking, past the very interesting posts about making spoons, to the part about using a froe and a brake to steer the split.
Pete Galbert's blog
