Project Nightstand Completed
Todd Nebel
I finished my version of the Stickley 3 Drawer Nightstand #613. The overall dimensions are 30" H x 22" W x 16" D. What I did differently was to raise the 2 rear legs, add a backsplash, and reduce the drawer hardware from 6 to 3.
The carcass is QSWO. I decided to use solid stock on the legs which meant having no rays/flecks. On my other pieces I would glue together two boards and add an 1/8" veneer front and back. The drawer fronts are also QSWO, but the sides, back and bottom are poplar. I would have liked to use white oak, but I was running low. The back of the carcass is a WO panel like the sides, just not a pretty.
Here are a bunch of pictures showing the progress and joinery details.
I was lucky enough to have some very figured boards so I thought I was doing myself a favor by using so much of it. Now that it is all completed and the finish was on I'm second guessing this decision.
I'm not happy with the hardware. I ordered Stickley hardware from Rockler.com and had to return all 3. The second set was marginally better, but still had issues with manufacturing and color.
Thanks, Todd
, white oak. I recessed them into the legs a full 1/8" maybe a little more. Rounded over the fronts just for looks, not that you can see them until removing the drawer of course. All the drawer runners are the same height 2 1/4" from the bottom. This was an oversight on my part. When it came time to route the groove in the drawer sides I didn't like where it went through the DTs on the back and met the DTs on the front of the drawers. Oh well, live and learn. Next time I'll plan that out better. You can see that I pre-mortised drawer stops in the bottom rails. These are 3/8" squared and set in the thickness of the drawer. You can see them in the pictures. Those worked out nicely.
