We value your privacy.
I was wandering around in antique stores a few days ago and I saw an interesting tool. It is a long ,wide(1 1/2 maybe?) chisel with the flat (non beveled)side machined with fine grooves right to the edge.These grooves are deep and uniform. I understand what a toothing plane is for but this tool puzzles me. How would one use a toothing chisel,and why? Something new every day.---Jack
I have a version of this made by D R Barton, and have seen a few more at Mid West tool meets. It is tanged so I assumed it was for turning. I imagined it was for toothing the venered QS oak columns seen in homes at the turn of the last century. I finally found a reference to one in a Phillips of CA tool catalog. They made patternmakers tools. The description said it was used to make a true cylinder when turning. The indication was that it worked better than the normal chisel. I use mine for scraping glue off furniture parts when restoring a piece and to tooth small parts when using hide glue.
turning hard materials like ivory, bone, burls, etc. as it works like a violin maker's toothed plane blade for curly woods. Ivory has layers that can cleave off, the toothed chisel keeps that from happening. Finished up by scraping off the tooth marks.
The company you referenced is Phelps mfg not Phillips. I don�t know much about the company but the tools were all patternmakers tools. They made a marking gage, a panel gage, a core box plane and a toothing iron with a cast aluminum handle. The marking gage is made so you can use it on straight as well as curved edges. The panel gage is the best marking gage I have ever used and I highly recommend it.
A toothing iron is used for turning in a couple of different ways. One of the most unique is for face plate turning. As most turners quickly learn it is not a wise thing to use a 1 1/2" wide chisel on a face plate due to the drastically different surface speeds at each edge. Doing the same thing with a toothing iron is not a problem since it is more akin to using 15 or 20 tiny diamond point tools all at the same time.
The description you referenced from a catalog about truing up a surface is true but not in the way most people would tend to think. Patternmaking uses tolerances of a few thousandths of an inch. When turning with a standard 1 1/2" chisel it will tend to follow the grain a bit and cut on the side grain and ride across the long rain and end up turning something that is out of round by a few thousandths and potentially out of tolerance. With a toothing iron it will turn a true cylinder. You then knock it down with a standard chisel. In patternmaking finish is secondary since you turn to dimension and then the wood gets painted and finished out that way rather than polishing the raw wood.
