We value your privacy.
I have three seperate saws that all want to veer left slightly when cutting. I suspect the problem is with my poor sharpening technique rather than my poor sawing technique. So I'm thinking if they go left, I want to take a stone to the right side of the teeth. Is that correct?
Yes, stoning is the right way to fix this. Even one tooth that is 1/64" protruding will tend to move the saw 1/128" in that direction with each stroke. After 20 strokes, you can see a deflection over 1/6 of an inch.
My method of precision stoning, is to lay a shim down on the stone. The shim needs to be the thickness that you want the set teeth to stick out on either side of the saw. Then with the saw body flat on the shim and the points on the stone, I use a few strokes on each side of the saw, to even out the set.
I use a large but inexpensive stone for this. Stoning a saw is rough on stones. I move the area stoned each time and then resurface the stone after I have mangled too much of the stone. A very nice, large and relatively inexpensive stone will be available in your larger oriental grocery stores.
The wider the set, the bigger the gap but the more work initially cutting, as you are removing more wood at a time. A large gap lets you turn and cut curves, It also reduces the pinch put on the body of the blade as the wood expands. Saws that saw cross grain green wood need lots of set to avoid binding as the exposed wood expands.
A smaller set will leave a less rough cut, and will tend to go straight. It also reduces your ability to correct angle as you go through the wood so you have to start your cuts out in perfect alignment.
For general sawing I like a very small set and have used a sheet of 20 lb paper as a shim. This will usually leaves me a finish about as smooth as 120 grit sandpaper would.
With no shim used you can eliminate set and turn a saw into a flush cut saw. A flush cut can leave a polished surface, but can bind in a cut easily.
Easy enough to see if it is your method or the saw. Try another saw or two. Better yet, get a bow saw with a 2 direction blade. Saw to see how it bends, then flip the saw. If it is the saw, it will go the other way.
I see you have made quite a few very helpful good "points" here.
May I add a couple cents for those who might be new at filing/sharpening/tuning a handsaw?
I use a silicone carbide slip stone for side jointing. It holds up better due to it's hardness.
I like your method of using paper shims for precision side jointing. However, the reason a saw will veer off line is mainly due to the original setting of the teeth. When the teeth are set equally on both sides, the side jointing merely removes just the very tip end of the tooth, just enough to make all the teeth exactly even and to remove any small burrs left from filing. If I have to remove more than that, I know I have not done a proper job of preparing to set the teeth or setting the teeth.
To prepare for setting the teeth, before I do the setting, I will, in effect, lightly side joint the freshly filed teeth to remove any burrs so the teeth can be set without any grit or other debris between the teeth and the anvil of the saw set. Also when doing the setting, I focus on applying the same amount of pressure on each tooth when using the saw set.
Even though setting the teeth is seemingly a fast and easy part of the saw sharpening process, it is equally important as the actual filing of the teeth.
