Probably more than you wanted to know .....
Hi Roger
Choosing dovetail chisels depends on the type of dovetails you make, the method you make them, and the type of wood you use .....
Further, dovetail chisels are essentially for the tails, not the pins. Pins are vertical and the only angle lies with half-blind dovetails. For the latter a skew chisel is helpful.
If all your chisels were wide, and the chisel width you choose is narrower, even the tails could be undercut with a firmer/slab-sided chisel used on an angle.
It is really when you plan to cut narrow tails (where there is restricted movement) and/or pare/chop into the corner at the baseline that a chisel with a minimal shoulder is needed. I enjoy making drawers with narrow, London-style tails in hardwood, and for this special dovetail chisels are indicated. The sizes I use are 1/8", 3/16" and 1/4". Wider chisels are used for the pins, such as the 3/4" super-steel versions I posted very recently.
As Pam noted, Japanese dovetail chisels are not the same as dedicated Western dovetail chisels, such the Blue Spruce. The BS are designed with minimal shoulders (as are the LN bench chisels). I have a set and they are superb for detail work. The A2 steels takes and holds a very sharp edge. Japanese dovetail chisels have shoulders. These can be ground away (be aware that the laminated steel layer is very hard). I recently posted a mini-review of custom Koyamaichi dovetail chisels. The standard Koyamaichi dovetail chisels are available from LV. I think that they are superb value for money, but still they are in the same range as LN.
http://www.inthewoodshop.com/ToolReviews/KoyamaichiChisels.html
The reason I have a set of these is that they are my preferred chisel for chopping, which is necessary with some of the local hardwoods. For those occasions that I work with softer woods - more typical of the US I expect - I will use a set of modified Stanley 750s. These have shoulders I ground away. There is a tutorial on my website if you want to go down this path ...
http://www.inthewoodshop.com/ShopMadeTools/Soyouwanttomakeadovetailchisel.html
