Re: japanese plane making
TomD
"Wilbur/ Pam,
I did some of the tweaking you suggested and have seen a very nice improvement in the performance of the plane. I reworked the bedding so the blade is not so tight. I assume this lessens the bulge,if any, behind the blade. It also makes adjusting the blade somewhat easier."
Any bulge shouldn't be a problem because that part of the plane isn't in contact with the wood, and even if it were, as with my western version, it would have been tuned with the blade at full depth, or with a shim so you get that engagement without having to lower the edge all the way.
Some of my blades are so loose after years, I adjust them by hand, but post seminar, I learned to set new planes at least, much harder. he virtually beat them in like a 6" spike. And I suppose it is also one of those things where you can't add it back as easily. If it is relatively tight you just drop it in, then you give is a few taps and it bottoms out at the perfect point. Harder to do if it is loose because too much depth is perfectly possible.
"I forged this blade and it is approx. .250 at the thickest end. "
Cool! That should be enough with smaller blades. Japanese blades aren't all that thick at the low end, the upper end is beefy.
"maybe this is not enough for the super fine shavings because of vibration? About 1/4 in.from the front of the backside of the blade is dead flat but I did not spend a lot of time getting all areas of the blade flat."
Bevel or non-bevel side? Either way, on the more mechanically made blades, other than the hollow, the rest of the surfaces are flat. That is a simple approach and works well enough. One needs something consistent or it will be impossible to print it in and have it a correct fit at more than one depth, or properly supported. The art level baldes, or decent blades are longitudinally convex on the bevel side. meaning they are thinner along the midline than the edges.
There is a curve. This means the ramp of the plane will be higher in the middle than the edges, and when you look at the line the ramp makes with the top of the dai, it will be a curved line. This is what i argue makes it easier to fit by chisel, as is their style.
"I am not sure the blade is bedded as well as it could be,"
I hate to admit it, but getting a really even blueprint is not happening, and is not necessary to high performance. It is amazing how little of the surface will be inked. I had a plane a while back I kept going back at the fit, and it was forever before I got a line of ink on the ramp within the abutments. Still worked great. Indeed when you go for bearing surfaces on cast iron machinery ways, you get very little actual contact, and you don't want it.
" but I assumed the tightness meant the blade was being held properly."
I don't think you can count on that, it can be wedged on three point. Endgrain is really hard, tons per square inch hard.
"Because the bevel is down and rests on the bottom ramp of the plane, I guess I should make sure the top of the blade is dead flat."
Huh? Are you talking about actual support to the bevel, as some go for, but I don't personally buy that much, or the whole surface engagement of the bevel side of the blade? And how does this relate to the side you want to flatten. Flattening the hollow side (whether you put one in or not) Is job one, I personally would not try to get away without that, you don't need a hollow, but if that surface doesn't have consistent bearing it will make life more difficult and wear more likely.
Indeed if one could, a good way to process would be to ensure the top of the abutments were really flat and coplanar before you moved on to other areas of fit.
