New WoodChat!
Dogwood and/or Persimmon
Patrick Gibbons
I'm wanting to turn some shaving brushes for presents and have some dogwood that I know would be beautiful but I'm concerned how the wood would stand up to water. Anybody have any experience? I also have some persimmon. Would that be a better choice for the use?
Re: Dogwood and/or Persimmon
David Barnett
Dogwood, Persimmon and other ebonies *LINK*
David Barnett
I've turned and shaped my share of badger shaving brushes and most (if not all) ebonies (f. Ebenaceae, g. Diospyros, persimmon = Diospyros virginiana), dogwoods (such as g. Cornus florida), and other tight-grained woods will work just fine. I prefer them to be thoroughly dry, however. I have never used a finish on either D. perreiri or crassiflora (Madagascar or Nigerian), and give the edge to Nigerian for fineness of grain but to Madagascar for blackness. BTW, Nigerian (Gabon) ebony color will eventually even out (usually).
On the one persimmon I turned (from an old driver head), I sealed it with Waterlox (brought out the color and contrast), then rubbed it matte. Caswell-Massey carries a persimmon soap dish and tumbler, so I wouldn't worry about water damage. As far as I know, dogwood shares many properties with persimmon, inasmuch as it was used as a persimmon substitute for clubheads. It's hard to damage either.
I've used epoxy to seal and finish wooden brush handles (never on ebonies, however) to good effect and Waterlox has worked well on the few species I've tried it on. As I usually epoxy-in the brush knots and bottom medallion inserts into the endgrain, my brushes are fairly well-sealed.
I've seen very old ebony and/or boxwood brushes with cracks (usually at the wider diameter or just above/below the smallest diameter) that seem entirely stable in display and occassional use (inserted new knots into a couple). They look very nice to me, cracks and all.
persimmon soap dish
shaving brush question
Bruce, a MN Galoot
Is that brush insert from Woodcraft a decent quality bristle, or do you have a different recommendation?
Also, Bill mentioned that you had a good recommendation of an online source for safety razor blades. Mind sharing? I can't get decent blades locally.
Thanks.
I don't know what happened to the commerically-made wood-handled soap brush I had at one time - maybe one of my sons has it now, eaten by mice or time, something. At any rate, it was of some anonymous fine-grained light-colored wood, and never developed any noticeable problems (checks, rot) other than the film finish flaking off.
If the person shaving is doing it right, the wood will be minimally exposed to water; and I believe it's true that a brush ought to be stored with the bristles down.
Don't know - although I use a double-edged razor and plan never to revert to any of the modern razors or an electron-muncher, I'm a bit of a philistine as to the soap and just use regular hand soap, lathered up in my hands. My hands are developing checks and rot, along with the rest of my body, but I don't think it's the shaving that's doing it.
David Barnett
Re: shaving brush question *LINK*
David Barnett
West Coast shaving is where I buy my blades. Great selection and prices. They have samplers that are worth exploring. There's so much difference between razors, creams, shaving styles and faces that it's not a bad idea to try a few brands.
I like what is generally called the Israeli Personna. My friend who has the same razor loves Feathers, which are too sharp for me.
You might want to read reviews on Badger & Blade, a terrific resource: www.badgerandblade.com.
I'll try to answer your brush questions after lunch.
West Coast Shaving
I`d use Teak
Bob Hackett
I`ve had excellent luck using Teak for everything from hammer handles to BBQ brushes.
Wherever something is going to contact water or have to be washed repeatedly Teak has never let me down.The grip seems to improve when it`s wet.
David Barnett
Okay. Knots. *LINK*
David Barnett
"Is that brush insert from Woodcraft a decent quality bristle, or do you have a different recommendation?"
Well, it's probably worth what it costs. It looks to be pure badger, a grade referring to what Anthony Turchetta describes as:
"Coarse dark hair with firm bristles, good for scrubbing and exfoliating, Value knot."
Nothing wrong with that. Many shavers prefer boar bristle and like a scrubbier scratchier brush. I personally prefer best badger grade. I generally find silvertip and especially the treated super badger too soft for me. Most shavers would be thrilled with the softer grades, though.
Although I've used Jagger, Simpson, and Th�ter knots (Simpson's pure badger is the only one in that grade I've liked), the Golden Nib knots are entirely acceptable for all but bespoke brushes specifying otherwise.
Then again, there's always http://tinyurl.com/AnotherApproach
The Golden Nib badger hair knots
David Barnett
As for grip...
David Barnett
... I favor my fine silver and sanded shagreen best badger shaving brushes -- one in ivory, the other in celedon.
David Barnett
Don't forget...
David Barnett
... brush and brush-&-razor stands are also appreciated and offer design fun and scrap use. It's nice to make the brush stand fit the brush handle, especially if it's of unusual shape, such as my tapered three-sided brushes.
Carrying your proposal to its logical end
there's always the rabbit soup recipe that starts, "First you catch your rabbit."
Though I'd hate to see Centralians headed out with their badger-catching gear. At least around here, they're rare critters - maybe not in the technical sense, but certainly in the infrequency sense.
David Barnett
I'd call it OT, but... *LINK*
David Barnett
Razors, both straight and safety (spokeshave vs drawknife), are handtools, by God, although I take no truck with those modern multiblade monstrosities.
"Don't know - although I use a double-edged razor and plan never to revert to any of the modern razors or an electron-muncher, I'm a bit of a philistine as to the soap and just use regular hand soap, lathered up in my hands."
Primitive. But hey, Andy Rooney confessed he used bar soap instead of shampoo, too. The first shaving soap I made (mid-'90s) had sandalwood, bergamot, and ylang-ylang essential oils added just before French milling. It was wonderful. Nowadays, I'm hooked on Geo. F. Trumper's shaving soaps and creams. And skin food.
Trumper's sometimes sells postpaid samplers
ThomD
The way you use a brush, it gets dipped in end first, then it sits handle down on the counter, but it is mostly just full of lather, then it get hung tips down on the stand. Doesn't get used terribly hard water wise.
Razor blades?
http://www.amazon.com/Merkur-Double-Safety-Razor-Blades/dp/B000QYCXSC/ref=sr_1_20?s=hpc&ie=UTF8&qid=1290885226&sr=1-20
There are a number of sellers. i was surprised to see they get only 4 stars. One guy gave them 1 star because he bought the wrong size. I have used the same half blade for several months when just shaving cheeks and necks. Also check the feather brand. I use the merkur in a straight razor which reduces a lot of the potential problems. Amazon represents lots of stuff.
There is also this kind of place:
http://www.straightrazordesigns.com/
David Barnett
I suppose there's synthetic.
David Barnett
I'd like to believe all badgers used in the making of shaving brushes die of natural causes. But I know better.
Famous last words
Bob Hackett
"How much trouble can a fat,flat weasel be"
From my old friend Dangerous Dan about 5 minutes before he had to run for his life with the badger in hot pursuit.
Re: Famous last words
Pam Niedermayer - Austin, TX
The PBS show Nature recently had a good show on badgers in N. America. Where does the hair/bristles come from? Didn't look like there were enough badgers about to be a source.
Pam
David Barnett
Badger hair species and sources
David Barnett
Most badger hair used in brushes is from the Chinese or hog badger (Arctonyx collaris), which is not protected and apparently a grocery item throughout its Southeast Asian range. It is hunted and trapped, never raised in captivity.
Earlier, the best hair was harvested from the Bern-Convention-protected Eurasian badger (Meles meles). DNA testing has recently shown brush knots in violation of the convention, so redoubled efforts to buy only from the most reputable sources is paramount.
By the way, UK badgers are protected since 1992, so I'm told sporins now sport Canadian heads. Heresy. Badgers are not protected in the U.S. except in national parks and forests.
David Barnett
How much trouble, indeed...
David Barnett
I recently heard about a young man who, following a badger encounter in Western Massachusetts, now maintains his testosterone levels exogenously.
Deficiency in early childhood education
Now, had his parents read "Wind in the Willows" to him in his youth, he might have had more sense.
Re: How much trouble, indeed...
Before anyone decides to challenge a badger, s/he should know they eat solid bone (yeah, all bones are hollow, but you get my drift) supplements in the winter. So if their jaws come in contact with human skin, know that human will lose.
Oh, yeah, and they climb 15,000' mountains in 90 minutes in the snow, so don't think a human can outrun them.
Pam
Re: Badger hair species and sources
I suspect we'll protect them real soon. First there's the Nature show, which discusses surveys and the like, then come the laws. But given their scarcity, no one seems to know how many or where.
What are "sporins?"
Pam
What I ended up doing...
Patrick Gibbons
I originally was turning handles from briar (as in pipe smoking briar) but found that the skew tended to catch quite often due to the difficulty of the grain and the inexperience of the turner. I finished one out of this and it's OK but not my favorite. I have dogwood and persimmon turning blanks but the dogwood is closer in size to what I need. (By the way, that persimmon soap dish does not look like my persimmon. Mine was originally intended for the textile industry and is gray in color which seems to have been preferred for its hardness. That soap dish looked like my dogwood.) I made the last two in dogwood and finished them with Liberon's carnauba/shellac stick. I hope that's enough. Maybe I will make some handle holders to go with them. I also like Trumper's soap but recently got some shaving soap from Ogallala Bay Rum that has a great consistency, is long lasting and smells wonderful (if you like bay rum, and I do). I'm bundling the soap, the brush and a hand-made soap dish Ogallala sells as a Christmas gift for the brother and brother-in-law and have one left over for myself. I just hope the finish holds up.
Medallions
Patrick Gibbons
David, what do you use for medallions? That would be an elegant addition.
ThomD
I don't know, can a badger climb El Cap in 2.5 hours? I'm not volunteering, but people have nailed leopard bare handed, so with the right attitude a badger should be in the brush pretty quickly.
Re: Medallions
ThomD
Coins,pins, and ball markers are good sources. Of course ball markers are mostly golf related, but there are other options.
So you all know, I just received the new...  *LINK*
Scott Burr in Ben Lomond CA
Penn State catalog and they now carry a lot of shaving related items. Just do a search for "shaving".
Penn State
