Re: thin chisels for dovetails
I saw David Charlesworth pare dovetails vertically, from the end grain, down into to the bottom of the tails and pins on one of his videos. I like the technique and use my Blue Spruce paring chisel to do it.
Today I decided to fool with a few narrowly spaced tails. The only blade in my shop that will allow me to pare vertically is an old Record block plane cutter ground at 25 and honed at 26. I don't like paring with a plane iron.
Anyone have a better solution?
Hi Les
I have done something that may be similar, that is pared vertically. However I have only ever done so on the pins, never on the tails.
If you cut the tails first, as I do, then these are the templates for the pins. You would only want to adjust the pins (if you need to adjust at all).
On the pins, if your saw cut is slightly inside the mark, you will see the knifed line. I usually just place the chisel in this and - carefully - push downward to remove a sliver of wood. You do not need a special chisel for this. Still, this can be a very risky method as it is too easy for the grain to deflect the chisel off line. It is better to pare from the sides.
Am I missing something here - did I understand you correctly?
