Dowel plates, draw boring &c
Patrick Gibbons
Just got my dowel plate from L-N. It's not a snap to get a piece of wood down to a size and shape that it will run through the plate. I guess I'm going to have to make a dowel jig. Oh, the pains of a lazy man. My problem is that the 1/4" dowel is a very loose fit in a 1/4" hole. I believe it's because I'm using a brace and bit. It's been my understanding that auger bits are oversized. What would I have used if I got in the way-back machine and ended up in the 19th (or 18th) century? Anybody have a successful way of getting a tighter fit? Will the glue cause the pin to swell to fit? Obviously I haven't tried it yet.
Re: Dowel plates, draw boring &c
There were dowel bits - shorter, and perhaps sized more precisely. someone who knows more will no doubt be along in a minute to add information.
Hi Patrick,
Scott Burr in Ben Lomond CA
Yes, auger bits are sized a bit larger than their stated diameter. They were made this way for screws/hardware to fit through the drilled hole. As Bill stated there are dowel bits that are spot on the diameter stated on the bit. I see them on Ebay now and again. I don't know if anybody makes them today.
That said, I have the LN dowel plate and I have had no problems using dowels made from it in holes bored with an auger bit.
Pam Niedermayer - Austin, TX
According to Jim Kingshott, in his mid-20th century apprenticeship he spent a lot of time making tree nails by hand and chisel.
Pam
scott grandstaff
scott grandstaff
It was the railroads.
After the railroads got going so strong, (not to mention the wagon industry, etc.) all auger bits were made for clearance over machine bolts.
All those beautiful sets you see in the cool boxes?
Yeah oversized, every one.
Dowel auger bits are about 1/2 as long. They do come around some if you look hard enough, but tough to find!
Square shank twist bits for drilling metal were made and these will work fine in a dowel jig too.
A Lion or holdall chuck brace will drive standard twist bits well enough for woodworking. Its what they were made for!
Everybody needs a lion or holdall brace anyway.
They are easy to spot, the chucks are twice as big as standard chucks!
Get you a Stanley #59 dowel jig. Nobody ever made better and you can get one for 15 bucks if you hunt. You want the old pattern which is solid cast iron. The later made aluminum ones suck as bad as every other more modern jig I've tried.
Dowel centers are essential too and those are still easy to get. For drill press type work they are perfect.
yours Scott
John Walkowiak
I use the LN dowel plate and have found that the only bits I have found that are the same size are the old Russell Jennings. They have always been an exact fit.
John
18th century
Warren in Lancaster, PA
In historic work we usually see tapered pins, not dowels. The pins are usually octagonal or roughly so, but sometimes fairly rounded, sometimes square. With a tapered pin the fit is tight and the taper helps draw in the tenon.
dowel plates as a patternmakers tool
Robin Corell in Atascadero CA
The dowel plates LN sells have their roots as a patternmaking tool. In wood patternmaking wood dowels are used to locate loose parts on a pattern as well as for precisely locating a part on a pattern as it is being built. For this to work the dowels need to be exactly sized and exactly round. Commercial dowels have a wide size tolerance as well as a tendency to be out of round. Most pattern shops buy their dowels from pattern supply houses and they are higher in quality and slightly over size. In use a dowel plate isn�t used to make dowels but rather to precisely size pre made dowels. One of the first things I did as an apprentice was to make a dowel plate. I wish I had made mine as nice as the LN.
I was surprised to see the LN dowel plates being marketed as they really don't have much application for most woodworking tasks. Don't confuse this with the notion that they are not worth the price. Having made one I can tell you it is not as simple as drilling a hand full of holes. The holes must be drilled under sized and then the correct reamer is used to size them. The cost of the reamers alone exceeds the cost LN sells the plates for.
Robin
Yeah, I've never had any sizing problems with the Jennings I use in a brace.
Pam
scott grandstaff
scott grandstaff
Oh way cool! I never had an Jennings, lots of other brands. Guess I have to round up some Jennings now!! I am delighted Thanks!!
yours Scott
Re: dowel plates as a patternmakers tool
R.J.Whelan
Being a bit lazy in my declining years, I buy most (all) of my dowels. Whenever I'm making the 300 mile drive to my favorite woodworking supplier I unscrew my L-N dowel plate from it's fixture and take it with me. I sort through the dowels and if they aren't a tight fit (or too large) I put them back in the bin and try another. Since buying this tool I have never had a loose fitting dowel (unless I got sloppy with the drill).
RJ
Hey Scott...
It could be your lucky day :D
I have a box of Jennings bits I'm looking to off. Email me off line and I'll be glad to show them to you.
Cheers!
Best of luck with this. I note that in a perusal on ebay, there were several sets that were called "Stanley Russell Jennings," and I haven't a clue whether they differ from the plain old Russell Jennings; however, they aren't that scarce, several sets on ebay right now.
Pam
