Old Irons
scott grandstaff
Take a file to your old irons first. If the file won't cut they are still perfect. If the file digs in easy, they have been annealed by the fire.
Send them to an expert if they are precious.
Rehardening, if you want a go at it, you hardly need much for.
Burgers and cake, are on the menu!
An old barbecue, a hair dryer or other air moving device, and a can of oil. Peanut oil is said to be second best behind sperm oil.
But old used motor oil will do in a pinch or anything else you can get real cheap..
Have a scrap of wood a little bigger than the oilcan handy too.
Get some real charcoal for the grill. Get it going good (use extra charcoal for later)
and ........
after the burgers are done and consumed,
stick your irons on top of and underneath some of the coals.
Rake a few more over top.
After a few minutes preheat time, take the hair dryer and bring one of them up to bright cherry. Some fiddling around with the air and placement of the coals is required and sparks will fly, so at least wear gloves and glasses.
When you get one blade up to bright cherry (dull red won't do, bright cherry looks practically alive), try to hold it there for at last a few seconds (soak time) and then quick, grab it and plunge it straight into the oil, cutting edge first. Sloshing around is good. Use long handled tongs (very large pump pliers, chanellock, will do)
Best to keep your hand away from the oil though, as it is likely to catch fire. Remember the scrap of plywood that is a little bigger than the oilcan??
Um yeah, do not panic!!
calmly,
smother said fire placing the wood gingerly over the can.
Good results can also be had with water but the water has to be HOT!! Cold water is likely to warp or even shatter your iron.
Put pure hot water into your can (a used to be 3 pound, now its 2 1/2 pound, coffee can is very handy). Fill the can from the tap with as hot a water as you got. Place a large piece of scrap steel in the fire with your irons. Before you quench, quench the scrap to bring the temp all the way up.
While you are waiting for the iron to preheat, mix your cake batter and preheat the oven. You don't want to wait too long after hardening your irons to start the tempering "process".
Put the cake in, and the newly hardened irons on the rack right next to it.
If you have a squeemy mate, use misdirection and quickly, hide the irons behind the cake pan. Nobody is going to taste anything "off" in the cake. But sometimes they can't be allowed to see it, to feel ok.
You might have to repeat the slight of hand, fetching them back out when the cake is done.
Eat cake,
sharpen your irons for the desert after the desert.
These methods are not the "tool boutique sales pitch" method. Some steel reacts better with water and some with oil.
But the key word in that sentence is better.
You don't have to have so much "better".
Better is a word people use when they want to sell you something.
People are going to write in and say this can't be done at all.
But I have been actually doing it,
not theory or something I read in a book somewhere,
for years.
Works damn good nearly all the time.
yours Scott
