A refurbed 16" Disston Backsaw
Dominic in Buck's County PA
Hi everyone,
I haven't posted here in a while and figured I was about due to check in with the crowd here.
Seems like lately I'm on a saw kick! Anyway, I found this old 16" Disston backsaw at a CRAFTS of NJ swap meet several years ago. It had been sitting in my tool cabinet waiting for the say I learned how to sharpen a saw. After my recent "success" (or as I like to call it, "NOT screwing up") with my Disston dovetail saw project, I decided to try cleaning this saw up and then take a whirl at sharpening a cross cut saw.
As you can see below, it's about 16" long and is filed for 14 TPI.
I believe it's a D-4 backsaw since they did offer it in 16". But it's plate is about 1/2" less "deep" than my 12" D-4. But that could have been from being sharpened a lot. Now if I date the medallion right it's from 1917-1940.
Update: I've been told that this saw is meant to be used with a small miter box, possible a Langdon. I've got some feelers out now for one and hopefully will be able to put the saw to use for that purpose.
So I took it apart to check and see if there was any hidden damage to the handle. Thankfully there wasn't any.
Under all that paint and gunk, the handle was in pretty nice shape. It looks like it is apple. After I cleaning it with lacquer thinner I sanded it up and gave it several coats of sealer, sanded between coats, then a couple coats of blonde shellac. Afterwards the finish was buffed out with wax and 0000 steel wool. I find I'm liking the natural look of a shellac finish more and more over super glossy glass like finishes.
And now for the reveal:
As you can see in the photo, there was some pitting on one side of the blade. Nothing that effects performance though. The handle cleaned up REAL nice as did the Medallion and saw nuts.
I sharpened this saw (using my shop built saw vise,) and set the teeth tonight. So after re-assembly I took it for a test run. I used an old piece of red oak and my bench hook to test this saws ability to track to a line.
At 14 TPI it was a bit slower going than my Wenzloff or D-4 backsaw. But it left a SUPER SUPER smooth surface. It almost feels like it was shot with a miter plane! And the blade didn't bind in the kerf at all!
I also tried cutting some tenons on a piece of scrap and was very pleased with how straight this saw tracked. I can see where this saw ill come in mighty handy for those instances I need to cut cross grain in order to define the sides of a dado.
I'm pretty happy with the overall results. I'm ready for my next saw project where I'll be making a Half back saw from scratch. THAT oughta' be an adventure! :>)
See ya around,
Dominic
