Tote Carving Plus
scott grandstaff
I'm not planning to tell you every little thing.
But if you take these basics and experiment, you can have totes, and as many as you want, the likes of which you can never buy for money.
Absolutely and most definitely you drill the long hole first.
Forget anything else, use oversized stock and drill first.
Everything else relates to the hole and there is no way in the world you are drilling an angled 5"+ long hole to fit outer proportions.
I like to go ahead and counterbore the hole for the barrel nut on top and the casting post on the bottom while I'm at it.
Counterbores are wonderful things, but very expensive.
Unless you can find yourself a surplus place near an aircraft manufacturing plant. Then they come by the dozen and very reasonably priced.
20 bucks a dozen instead of 30 dollars apiece.
Once you have the hole prepared, adjust the bottom angles to fit so it sits on the plane well.
Only then, can you begin to design and carve your tote shape.
Since you are carving from scratch, why follow a standard pattern?
Its true the mid period Stanley totes (types 5 to about 8 ) are about the most beautifully proportioned totes ever commercially offered, imo.
But hey, you got more time and you can do at least that good!
I suggest you get a selection of old totes, or at least some decent pictures, which you can copy and save to your files off ebay auctions if nothing else.
So......................
What size do you wear in a glove?? Got size 6??? Size 11??
What you packin' at the end of your arms?
If you are a size 12 you will never fit all your fingers inside a metal plane tote of any kind. But anything less than that, you can accomodate your grip if you work at it.
Then, we move to your work style.
Do you mostly work from a sawhorse where you are leaning over far over the work? Or a high bench where you are mainly pushing forward??
This determines your totes vertical angle, whether leaned forward (if you are over top) or more vertical, if working from a higher bench.
Most totes were made for a reasonably high bench and average height mechanic, btw, so there is your starting place.
Now we come down to grip.
The human hand on a plane handle wants to curl the index and second finger rather tightly. This grips and controls the plane. Like the tiller of a ship.
You don't want too small, nor too large at the throat.
The bottom fingers less so, more just along for the ride.
In the matter of pushing, it all comes down to the heel of the hand. This is where you push through the wood.
Nearly all commercial totes were made from minimum stock. This is a very big deal if you are making 10,000 totes, considering the price of tropical hardwood.
So, Spiers was about the most generous totemaker, weighing in at almost 16/16" stock. Stanley was pretty far down there at under 7/8". The thickness of the stock is important for the grip but also important for the pushing. Pushing hard and long against a skinny narrow tote is not so comfy.
So, for myself, I prefer a narrow throat and wide comfy, cushion-for-the-pushin' style,.............. down below.
This is Stanley, Spiers and mine for comparison.
I start will full 6/4 stock.
Areeeeeeee you gonna take me home tonight?
Fat bottom girls you make you rockin world go round!
yours Scott
, but I found it worth the effort to be able to use 1/4-20 all thread and make the rod whatever length I need.
