Blasphemy
wilbur
So last night I went to mark and cut the mortises in the underside of the benchtop that will accept the tenons on the top of the legs. As I did before, I sharpened up my trusty 1" mortise chisel that I used to chop the mortises in the legs for the stretchers, drilled a hole for the waste at one end of the mortise, and proceeded to start chopping.
Except.
Anyone who turns up their nose at Douglas fir because it is a softwood can go take a flying leap. Softwood or not, chopping that mortise was like trying to chop through concrete. A little while ago I had, in a moment of temporary insanity in response to a post on another woodworking forum, chopped a 1" wide mortise in some hard maple just to see if it could be done. That was easier to do than what I did last night, by a lot.
I think what happened is that [1] the growth rings on the wood I used for the bench top are much more closely spaced than the wood I used for the legs, and (b) the benchtop has been sitting around for a while since I chopped those leg mortises, and the residual pitch in the wood has set, making it harder. I know that it's almost impossible to drive nails into old 2x4's that make up the frame of an older house, like mine.
I wound up using a drill and Forstner bit to get rid of most of the waste, but I have 7 more of these to go, not to mention the 2"x2" square for the planing stop.
So I found myself late last night reading up on -- routers.
Any suggestions? I figure that if I'm going to get some input on routers, I might as well get it from hand tool enthusiasts.
I'll also take suggestions on alternate ways of chopping these mortises. I'm going to try chopping each side of the mortise with a 1/4" wide mortise chisel, and then wasting out the middle.
