Workbench taking shape, then two steps back
wilbur
>I've made some more progress on my workbench. I finished the assembly of the base, and put it on top of the benchtop to mark out exactly where I should cut the mortises to hold the benchtop to the legs. This is really the first time I really have an idea of the size and scale of my workbench.
I knew that at some point I was going to hit a snafu with this project, and apparently that time has come. The stretchers are all held in with drawbored mortise and tenon joints, and although I swear I test fit everything twice, when it actually came time to glue the stretchers into place, the very last stretcher bound up and stopped about 3/32" short of fully seating into the leg. This resulted in a little bit of a twist in that leg compared to the others. Of course, what I needed most right then was a couple of 5-1/2' long clamps, and the longest ones I had were 48".
I wouldn't care so much, except that this was the leg that makes up the leg vise, and this is the one leg that really needs to be square and flush with the front of the benchtop. In the picture, it's the far leg on the right that's a bit out of square, and it's the joint it makes with the long stretcher that has the gap.
If I set the base so that this leg is square, the other legs will be off enough so that the mortises for the top of the leg in the opposite corner will be too close to the edge.
If I set the base so that the leg vise leg is a little out of square, the hole that I already drilled for the leg vise screw and the slot for the parallel guide will be out of square with the front plane of the benchtop, which will make the vise not work correctly.
I thought about attaching the base so that the leg vise leg is out of square, planing down the face of the leg vise so that it is square with the base, filling and redrilling the hole and the slot for the parallel guide. But given the amount of work that seems to be, I'm more inclined to just cut the stretchers off, and redo the mortise and tenon joints. To maintain the length of the stretchers, I would cut a notch in the stretcher and make a large loose tenon to fit. Besides, if I do the patch job of filling and redrilling the hole and parallel guide slot, I'll think about it every time I use the bench.
I'm pretty ticked off that this happened, but I'd love to hear suggestions on what to do.
, and clamp it all together.
