Ok, now I see them.
Ok, now I see them.
Ok, now I see them.
Parisian, VL
8) :D
So what are all the other buttons about?
and why are the messages all running over the right side of my monitor here, but not at work?
Victor
Re: Ok, now I see them.
Dan Donaldson
>Can't help with the overrun (mine does not do it), but the other buttons are for formatting stuff in the post. You can hover the mouse over them and get a tool tip that tells you what each one does.
The top row are basically font formatting options for size, type, alignment and color. The bottom two are for loading images you have on the web somewhere and the last one is a quote button.
The text below was posted using the quote button. (a dup of above)
James Watriss
>The other buttons are about half an inch wide.
:D
font size ?
Larry Williams
>Not sure how to do it on a MAC but if you're using a Windows machine you can change display font size by pressing [control] and [+] or [-] at the same time. If you have a wheel mouse, press [control] and scroll the wheel.
Close your left-side toolbar
>Another visitor with the same symptoms just reported to me that he had a history toolbar turned on, and although he couldn't see it, it was taking up space on the left side of the screen. Any browser toolbar will do the same, and if your resolution is set at only 1024 wide, that will push our page off to the right. See if this is the problem.
