Help with eggbeater
Wiley Horne--So. Calif.
>Hi All,
Well, today I received a Goodell-Pratt #5-1/2 hand drill from an ebay seller. 3/8" capacity chuck.
When I put it together, it certainly appears to be a substantial and smooth-running tool. Makes me think a lot of Goodell-Pratt.
But. There's something the matter with the chuck. Does anyone have a drawing or section through a Goodell-Pratt chuck (or any similar chuck style)?
Here's what I see.....The chuck threads onto the main drive shaft of the drill. However, it doesn't go all the way, and the three jaws are out of whack, one running ahead, one lagging. So I unthread the chuck and look inside to see what's going on. The three jaws appear to be tied together into a unit by three springs. Looking down the other end--the threaded end--of the chuck, there is some sort of stud in there. This stud is floating loose. It has one conical end and one flat end.
Does that sound like the original part that's supposed to be there? I would think 'yes', because it couldn't be an odd or end that someone just dropped in--too specialized.
If it is the right part, how does it go? Looks like it would engage the jaws better, if the conical end were aimed into the jaw assembly. Is that how it goes?
Also, is any part missing? What else is supposed to be in there.
Finally, that little stud thing is turned cattywompus in there right now, with the conical end aimed back toward the threaded end of the chuck. Has anyone ever managed to turn that thing around without taking the jaws out of the chuck? And if not, how do you get the jaws out of the chuck?
All help appreciated very much!
Wiley
