Quick question on flitch cut logs
wilbur
>Over on the Woodnet classifieds forum, a flitch cut cherry log is up for sale.
My quick question is, can anything be done with the very top board? It seems pretty thin, and is all bark on one side. My bet is that it's too thin to make a natural edged bowl or platter. What could you use that board for, besides firewood?
Re: Quick question on flitch cut logs
Stuart Hough
>Hi Wilbur, I would think that after cleaning off the bark, you might be able to cut the remainder into long strips you could use for edging or possibly moulding, though I am by no means an expert.
Warren in Lancaster, PA
>I think most would throw that piece away. Wild black cherry (Prunus serotina) has a band of light colored sapwood which averages about an inch thick. The top piece might be all sapwood. Probably the second board has quite a bit of sapwood also. Some people like the contrast between sapwood and heartwood, some stain the sapwood to match. I usually arrange things so no sapwood shows. I have used cherry sapwood for inlay sometimes. One of the advantages of flitch cut lumber is that you decide what to discard rather than the sawyer. Also you have a pile of lumber which is nicely matched for color and figure etc.
Also known as plain sawn... *LINK*
Alan DuBoff
>Wilbur,
Most loggers refer to this as plain sawn, it produces the largest amount of usable wood from a timber.
You can do stuff with the bark, but that bark doesn't look as usable as others, such as birch, which was popular to use in the Adirondaks on the older camp style log homes.
Here is a pic of how it was used, not a great pic, just found it on the web. Again, this style used birch bark.
HERE is another dresser from the same site.
Adirondack Furniture Site
Re: Also known as plain sawn...
Robin Corell in Atascadero CA
>The log will have a mix of plan, rift, and quarter sawn wood. the outer boards will be plain sawn ant the one cut through the heart will be quarter sawn. In logging terms the log was cut through and through. this means the log was placed on the mill cariage and cut from one side through to the other without cutting into a cant or truning and cuting for grade.
I discard the cap cuts so I can stack another log on top or a piece of OSB to shed water. I don't strap my logs like that but if I did I would do it where the stickers are. Its not a bad idea, I just have too many logs to be able to afford the necessary number of clamps.
Robin
Haven't heard referred to as through and through
Alan DuBoff
>Robin,
I haven't heard it referred to as such, but it makes sense.
This is what I normally hear in reference to milling timber.
Re: Haven't heard referred to as through and throu
>That is really way off, Alan. The second two drawings are both quarter sawing strategies. And the first, like Robin said will have some plain sawn boards and some quartersawn boards.
Dale Lenz
Dale Lenz
>Could make some rustic signs.
Plain sawn lumber
Bob Hackett
>The top and bottom boards are mostly sapwood and pretty much considered firewood.The center(or dog board) will contain the pith and is bound to split through it.The best way to deal with this is to locate the pith and then just rip the board about 1 inch on either side of the center of the pith and put that in the firewood too.
I`d put some Anchorseal on the endgrain(looks like it was painted)and then either re-strap it tight or stack it up off the floor/ground and cover then put some weight on it.The function of the strapping/weight is to help keep distortion during drying down.
Feel free to ask any other questions either here or by e-mail.
Hope this helps some.
Mainely,Bob
Stephen Shepherd
Stephen Shepherd
>wilbur,
It is also called slab sawn as the wood is slabbed from the timber.
You can make tea from the bark, great for colds, the flu and other respiratory problems as it contains small amounts of strychnine.
Stephen
Flitch does not equal plain, and other stuff
Bill Tindall, E.TN
>Refer to my article on hardwood lumber production in the Articles section to see how a log like this would normally be sawed. The picture shows a flitch cut log. This is normally the worst way to cut a log and it is never done this way commercially because the log will yield more high grade lumber if it is sawed as illustrated in the article.
There are two disadvantages to flitch cut. First, the middle three boards will shatter down the center as they dry. Cherry is the worst for this problem. It is common for a mill to reject the center 3" of cherry to pallet lumber because of the tendency of the heart of cherry to shatter as it dries. So, those nice wide boards you think are in there won't be after drying. Well, they will still be wide, but not nice.
Second, by turning the log as it is sawed the sawyer can get more clear lumber. Defects and sap wood can be concentrated in fewer boards. At worst every board on the top of this stack may have a knot that could have been localized into one board if the log had been turned.
Additionally, bark edges are a nuisance unless you are into the fad of bark edged furniture. The mill would normally have produced lumber with straight bark- free edges ready to use.
Finally, this flitch is a pig in a poke. Just the fact that it was flitch cut suggests it was done by an amateur. Who knows what grade of lumber lies within? It may be all #2 and #3 common. Or, half or more could be FAS. About a factor of 3 difference in the price of these possibilities.
More finally, it is a pain drying such a small lot of lumber. A lumber stack needs to be weighted to keep it straight as it dries. Cherry is particularly a problem because of the huge difference in shrinkage between the sap and heart wood. The fact that this lumber is not trimmed of its sap edges exacerbates the problem. If you had a 500 bd ft log-run stack the best lumber could be put on the bottom and the junk on top to hold it all in place.
Re: Flitch does not equal plain, and other stuff
Bruce, a MN Galoot
>I understand the business about the heart being problematic, Bill, but what about if you take the heart out and you're left with true quarter sawn stuff on either side? Are those pieces problems, too?
Bruce
Not a problem
Bob Hackett
>I`ve had very good luck taking what alot of bowl turners consider a scrap board and converting them to 2 very nice true quarter sawn boards.
As long as the check prone pith and early wood is removed you`re good to go.
See my post above.
MB
agreed
Bill Tindall, E.TN
>Had this log been sawed for sale of the lumber by an experienced mill it would have been sawed and turned repeatedly removing all the clear or nearly clear faces from the cant, until all that was left was the heart of the tree, often a 3 x 5" piece. This remaining cant would have been sold to the pallet factory. The pallet factory would resaw the cant into pallet boards or used this thick piece to make the spacers in pallets.
These flitch cut logs are the easiest way to saw a log on a portable band mill. It would be nearly impossible to saw a log this way on a large commercial sized mill nor would a mill want to do so.
