A quick tutorial ... PIC *LINK*
>Hi Wilbur
This is an extract from my review of the Veritas Small Plow Plane (link below):
Dados
Dados are grooves that are cut across the grain. This is not typically the province of a plough plane. I needed to cut a total of 8 dados. Generally I prefer to chisel-and-rout out (with a router plane) the waste.
The weakness of a plough plane lies in its lack of a nicker(s) to score the surface when cutting across the grain. This can be overcome by scoring the wood deeply with a knife.
Knifing the lines.
The next step is to chisel out some of the waste against these lines. This defines the outer edges of the dado and may be used as a fence against which the edges may be deepened with the aid of a backsaw. I chose not to do it this way this time, and instead planned to rely on the plough plane to maintain square sides.
Chiseling the waste.
The next step was to define the depth of the dado, which was done with a cutting gauge at both sides.
Marking the baseline.
The ends of the dados were chamfered to the depth to prevent unwanted breakout. Note the use of the chisel being used bevel down.
Chamfer the ends.
The fence was removed from the Veritas since the dados were to be cut in the center of the board. With a correct dado plane, a baton would be used as a fence. These plough planes could not be used this way as there was no place to use a batten. The plan was to run the side of the skate against one of the chiseled fences.
Running against the chiseled fence.
Planing one way (against the chiseled fence), then the other way (reversing the board to do so), produced very respectable dados.
It is not recommended that one attempt to plane both side of the dado by running the plane in the same direction. The skate running against the fence minimizes breakout. However, the open side of the plane against the fence can easily cause breakout. See the picture below. The right side of the dado is clean, while the left side has evidence of breakout.
Completed dado.
Dado with fitted divider �
How practical is it to cut dados this way? Well it is certainly possible, as demonstrated. And it is quite quick. I timed the last four dados to take a total of 16 minutes is all to go from marking out to fining tweak. But would I do it again? No, I think that I prefer a router plane to remove the waste. It can take a deeper shaving with less threat to break out.
The Veritas Small Plow Plane
