That would work, Scott *LINK*
Wiley Horne--So. Calif.
>I get a feeling you're used to doing mechanical design. Yours is a better idea than mine.
Here is the track (see link below). Goes into a dado 3/8" deep. The bolts slide along the track, as you can see. But it's not clear how much clearance there is under the sliding bolt head, to accommodate holddown screw heads etc. Cross-section is shown in 'View', but it's not dimensioned. However, just eyeballing it, you can see that a flat-head fastener and a shallow countersink would work. Thing is, in 3/4" ply, which I think is actually 1/64 or 1/32 less than 3/4", you have a little less than 3/8" of ply for the screw to get a bite into.
The reason for wanting a screw in there, is that a pair of these tracks is in the lower half--the base half-- of the sticking board. There is another board--the fence itself--which will ride on top with the bolts sticking through it and capped with 1/4"-20 knobs. So in a sense, tightening the bolts is trying to pull the track out of the lower board (yeah, I know the top board is pressing down, but it's the principle of the thing).
LV has fluted the outside of the channel to enhance the glue bond--so they must be thinking epoxy, or else some of our chem. engineers will be on their case about the nature of glue bonds.
I like your solution better than the one I was thinking about, because the screws are so short, and a machine screw will have more threads in play, and the threaded insert will provide better holding than the BB ply.
Epoxy is probably the best solution, but glue I can't wash off gives me the heebie-jeebies.
I'm pretty sure Stephen will advise that a little fresh garlic will prepare the metal for hide glue just fine (I didn't want to repeat the word 'aluminum' in Stephen's presence, so I said 'metal'.)
Thanks a lot, Wiley
Track (from Lee Valley)
