Workshop crisis #1207 *LINK*
>This follows somewhat on the recent thread about workshop size, and what may be done with it.
I managed to get a bit completed this weekend with the small wardwrobe I am building for the guest bedroom. (Lynndy asked for a small cabinet that could hang clothes as well as including drawer(s). The deal is that it must fit into a small room and, therefore, needs to be quite shallow. So my design arranges the hanging direction forward rather than sideways. There will be a central rail accessed by two side doors. I will show the final result when completed).
I have completed most of the carcass proper. I am thinking of calling it the "dovetailed cabinet". The sides and upper side are through-dovetailed, and the lower two dividers are sliding dovetails. The remainder of the design (two raised panel doors and one long drawer) will be attached to face frames).
Firstly, I can now answer the question (from a few weeks ago) about setting up a moving fillester blade - should it be in line with the outside of the plane body, or should it extend minutely beyond it? The short answer is that it should extend minutely beyond the body and in line with the knicker if planing across the grain. With the grain does not matter (one does not need a nicker when planing with the grain). More on this (with pictures) at a later date.
Secondly, the issue of assembly in a small workshop once again reared its ugly head. The questions for the Learned Readers are how do You cope with largish assemblies (a) on your own, (b) without an assembly table, and (c) in a small shop?
Step one - I attached two sides, balancing the free end on a small ladder while I connected the dovetails at the other side. Sorry no picture. You will have to use your imagination!
Step two - I held the third side by clamping it to the bench, and then brought the first assembly over to it and joined the two. This is easier said than done as it must go in square. Use of levels, corner braces, and much swearing is essential.
Step three - after the glue has dried, turn it on its side and slide in the upper sliding partition. Turn upright, check for square, and clamp until dry.
Step four - this can only take place once I have built the lower section. This is a mortice and tenoned frame (not a solid section) upon which the large drawer will run. This connects via a half-dovetail. Still to be built.
Moving this Tasmanian Oak frame was hard enough. Balancing it was harder ... where is the third hand?!
What would you do differently?
Finally, I did complete a re-write of the article on "Sliding dovetails by hand". There is a link below to my website.
