Re: Things that hand... easily - or so you think
ThomD
>"It may be easy to take off a thou with a power tool, but, at least for me, it would be a lot easier to take off 1/16" when trying for a thou ;-)"
Well they make those nice hand tools that take off the thous on power tools that take off thous or tens.
There are three ways of looking at this(just for starters): Taking off thous, taking off thous within a thou, and taking off several thos with a thous accuracy:
- Planes set to take a thou shaving, are very good at taking off a thou shaving, where that thou is relative to anything else is another mater. And for that mater whether that thou is fat or thin and consistent is another mater.
- Which takes us to making things not only a thou smaller, but an actual precise dimension everywhere, admitedly not even required in a lot of cases, though if one made guitars, or anything else where the parts had to interchange, one might care a lot.
- The third case taking off several thous with a thou or better accuracy, is a piece of take, shim stock or incra jig kind of deal and is very quick with little set-up.
To some degree, if you don't have tedious set-up, you just aren't working very accurately. And enjoy it for as long as you can! I do enjoy the fitting of parts to other parts because it is so easy, compared to making precise parts. Compare making to completely separate dovetail parts that never see their mate till assembly, with the usual process.
" I can do a lot with power tools, but the setup can be nasty for a lot of things. I have a Leigh jig. It makes dovetails very well, but if I am only doing a couple of drawers or one case, it is quicker to cut them by hand than to set up the jig and the router. This is also ignoring the fact that I can make DT's by hand that would be impossible with the jig."
I think there is a nomenclature issue here, a Jig isn't a power tool, it is some part pattern, fixture etc... Its usefulness is its repeatability in form, so to criticize it because it is repeatable, but not absolutely variable is not really fair. Most of our tools have some component of a jig, and pattern to them, be they chisels or planes, or saw, or router bits. But when they are so limited they fall into the jig catagory, we tend to lable them as such. The Leigh jig is pretty quick to set-up, but I rarely use mine for some of the reasons you set out. When the idea is just to get some dovetails in there for a structural joint, I have some ways of doing that that are faster. When it is a mater of doing really interesting dovetails, the Leigh ones aren't interesting enough.
