moulding plane iron service
redcoat
>Didn't someone years ago post about a moulding plane iron regrinding service. Mail order I think. Send the iron and plne so they could match the sole. maybe it was on Badger pond...
Justin
redcoat
Justin
Re: moulding plane iron service
Chuck Nickerson
>Depending on the tools you have and your budget, it's not very difficult to do. If you can spring for the $25, I'd recommend Larry William's DVD on making side escapement planes (available from Lie-Nielsen). I've now ground/reground 20+ irons. It's much easier than I though it would be before taking Larry's class.
ThomD
>And if you are going to get someone to do it for you anyway, might as well give it a shot since: A you probably can't go too wrong at first, and B you are going to get/have someone to clean up your mess pretty soon anyway.
The thing to keep in mind is that the plane cuts in the direction it is pushed, It may cut a semi-circle, it may have a blade that is an elongated semi-circle, but the wood will not get cut coming from all directions, it runs over the blade in one direction, be sure you have your edges and clearances in that direction.
It is best to learn it yourself...
Scott Burr in Ben Lomond CA
>I'd never trust a stranger with one of my blades. Patience is a virtue after all.
