stones
redcoat
>I picked up some (oil/wet?) stones in shop made boxes (hacked out of solid). Water beads on them. But are they oil stones, or just coated in shop muck?
stones
redcoat
I suspect they're oil stones
Bruce, a MN Galoot
>coated in shop muck. I was given one of those really long Norton tri-stone things and I cleaned them with some lamp oil or mineral spirits. They turned out very well.
What do they smell like?
Bruce
clues
Wiley Horne--So. Calif.
>Justin,
Are they regular rectangles? If they are, doesn't tell us much, but if they're not, it's a clue.
Are the stones thinnish, like 5/8" or less; or are they fat boys, like 1" or more?
What is the underlying color? Like if you give it quick lick with the belt-sander to cut down through the muck, what do you see? And does the stone cut quickly with a belt sander (if it does, STOP) or does it resist and not shed much?
Wiley
Re: stones
Alan DuBoff
>A picture is worth a thousand words...
Re: clues
redcoat
>Coffee with 1 cream brown. 3/4 to 7/8 thick by memory. Maybe 7 x 2, but perfect.
What's a belt sander?
Jusin
Re: I suspect they're oil stones
redcoat
>Badger pee.
Re: clues
>Justin,
Watch out for the badger, he's breaking bad.
They're the right size and color for India stones. On the small side and not the right color for manmade water stones. Bottom line: Bruce is right.
Wiley
Re: stones
Tony Z
>Is the box a fancy, hand-carved container? Are the stones loose in the box? If so, have you tried to clean them? Do you have any other stones in your shop of known type? If so, do a comparison by scraping your fingernail first on one and then on the unknown stone to determine how fine the unknown stone is.
Do some preliminary detective work and then post a picture or two and I'm sure some of us will come up with some cleaning suggestions.
T.Z.
