Show me your Toolboxes and/or Totes
Alan DuBoff
>I'm getting ready to build a toolbox/tote and wanted to see if anyone had any pics of one they have done. I am looking to build an open style tote, and would like to dovetail the joinery.
I found this plan on the popular mechanics site which I was thinking about modifying.
I was thinking to put tails on the side panels, and pins on the bottom piece, to hold the bottom securely as tools are put inside. But for the back and front panels, I was thinking that I would want to secure the sides from pushing out so would place the pins for that in the end boards and the tails would go on the back/front panels.
Anyone have any pics of a toolbox/tote you have built using dovetail joinery?
Regards,
Alan
Re: Show me your Toolboxes and/or Totes
Re: Show me your Toolboxes and/or Totes *LINK*
amelon
>Alan,
Here are mine, though they're not of tote design. I was influenced by Jay van Arsdale, my teacher, and Makoto Imai, his teacher.
- Bob
More toolbox photos
Practical aesthetics
Wiley Horne--So. Calif.
>Welcome Bob!
Those toolboxes are mighty pleasing. So many small details that are beautifully done--the joinery, the grips and how they differ, the nesting, the winding sticks.
One thing I couldn't quite figure out. I see that the larger box has compartments for planes, and it looks like there is room above the planes for a tray--is that where the chisel tray fits? Or does the chisel tray fit into the smaller box? Or is the chisel tray a third separate component? By the way, that Yokoyama plane is a treasure; I would like to ask at some point about how the togo reigo alloy sharpens, compared to white or blue steel.
You are following in some great footsteps, speaking of Jay Van Arsdale and Makoto Imai.
Wiley
Those are nice boxes! *LINK*
Alan DuBoff
>Bob,
You must be in the bay area if you study with Jay van Arsdale, I've not been able to get over to any of his classes, but live in the South Bay, over by Cupertino. You must be in the bay area somewhere.
I have pondered a style box like yours, and if I was to do that, I would incorporate the top into a stand, but one of the problems I face is the size of the tools I need the tote for.
I'll be using it for timberframing tools, which the chisels are 15"-17" long. I would like to have them displayed for use, so I can take them around and set them up while I work on the joinery.
I was pondering over doing something like Yeung Chan's toolbox, where I could open it up and use like a stand, but I'm gonna be dragging it around a yard to build a home. I think the traditional carpenter tote style will work better for that, and what I was using at a friend's a couple months back. I don't need a lot of tools, but need about 5 chisels, 1 block plane, 1 jack plane, framing square, 24" level, pens, rules, etc...
Would be nice to be able to incorporate a 4' level also, might be possible to attach it to the outside and point it up on a carpenter style tote.
I do like the style box you built, and have been wanting to build something like that for my bench chisels.
I did post a thread recently on my project, but unfortunately I lost one of my servers and my blog was not recoverable...I was able to kinda sorta piece it back together, but in the process none of the links seem to work...so that thread is missing the pics...:-(
I'll put a link below to my blog so you can see what I'm doing, go back around may/june time...
I will need to look over your site, looks like a lot of cool stuff.
Cheers,
Alan
Crafting blog
Eric Hartunian------WebKitFormBoundary+BvuD5+qdjoS
>Bob, great box, but I have a question about it. It appears that your box has the bottom glued or nailed on to the bottom edges of the box. I've noticed this on most Japanese style toolboxes, as well as various tansu. Do you find that this causes cracks, or any other issues related to cross-grain wood movement? I'd like to do a chisel box similar to yours, and always wondered how to keep the box shallow, but still house the bottom is a groove. Your method sure would be easier.
Thanks,
Eric
Show me yours and I'll show you mine
Marv
>For the kind of tools you'll be hauling around, I'd put wheels on it.
Get yourself an old sturdy ironing board and use the scissors mechanism that raises and lowers it so you can raise your tool box to waist height. Probably have to reenforce it some.
Nother idea....get one of those two wheel acetlyne dollies and build your tote to fit it or some other light weight type dolly. Or a golf club cart.
These are the type of ideas that oooze out of half a brain. Sorry.
Marv
Not a bad idea...
Alan DuBoff
>Marv,
I actually like the idea of having a portable box that could lift like that, and a dolly could work to build something like that I guess, just seems a simple box would do.
In the picture below you can see how the tools end up scattered around the log one is working on, but at some point one needs to gather all of them and move them out of the way so the log can be moved and/or placed on the building.
Too much becomes a burden, so the mobile idea is not bad, but would probably require separation as well since I may need to take the tools up to work on a log that is placed on the building.
What I was thinking is that if I had a slightly longer version which was 24" long inside, I could store a 24" level or the long end of the framing square inside. It could be small like the one in the pic here, since in this case the levels are carried in vertical position. I could still do that with the larger size anyway.
(I bet it's been hot out at the lake, been pretty warm here today and gonna be warmer by a tad tomorrow).
Cheers,
Alan
Kenneth Martin Sacramento
>Alan,
Here is one I built years ago. There are no dovetails, I used sharp metal thingies. It is 31 1/2" long, I added two blocks w/slots for the saws and a plywood divider w/cleats to separate them from the other tools. The square fits between the divider and the blocks. I found a Mayes 28" level that fits between the cleats for the divider. The yellow box I use to hold small tools and parts. Hope it gives you some ideas.
Ken Martin
Re: Practical aesthetics
amelon
>Thank you for the warm welcome, Wiley. I've been lurking for some time and finally decided to participate.
Yes, the space above the compartments allows a chisel tray to fit inside. I have a chisel tray which I move around different toolboxes, as seen here. I'm planning to build a new toolbox this year and this one will have multiple levels. It helps with the organization.
The Yokoyama "En" blade is quite nice. It's been my go-to plane for the past 2 years. I made the body for it at the 2007 Inomoto plane making seminar at Japanesetools.com.
- Bob
Re: Those are nice boxes!
amelon
>Hi Alan,
I live in East Bay (Fremont) but I work in Sunnyvale. I'm keeping a close watch on your project. Looks very interesting!
Tolpin's Toolbox Book has a lot of ideas. I flip through it quite often for ideas. Since you may not be carrying many tools, a hexagonal tool roll (seen here) might be a good idea. It can be made long to fit your timberframing slicks/chisels and open up fully for presentation. I think it looks pretty cool and will build one in the near future.
Another thought is to incorporate a removable tool tray in your toolbox. On the job site, you can put the tools in use in the tray and then carry the tray from place to place. It helps with organization. I saw the Japanese carpenters do this at the 2007 Timber Framers Guild conference and I've been doing the same. See some photos:
tool tray 1
tool tray 2
my tool tray
I chose the toolbox style I'm currently using because it's easy to haul it around the job site. Just lift it onto my shoulder and it stays pretty balanced. I can carry 50-70 pounds of tools for a short distance comfortably. Like so:
carrying toolbox - front view
carrying toolbox - back view
So many design options to consider... B-)
- Bob
amelon
>Hi Eric,
The glued/nailed bottoms have been holding up rather well thus far. I'm thinking of Toshio Odate's toolbox which is all nails (not even glue) and it's structurally sound. This toolbox I've had for about 3 years and it's not showing any problem sign yet. Aesthetically, I like the grooved version. I put grooves in my recent toolbox here. Unfortunately, it felt too big and unwieldy so I gave it to my wife to store her yoga stuff, which proves that toolbox can have other lives B-).
- Bob
Re: Practical aesthetics *LINK*
>Bob,
Amazing how many topics in cabinetry and carpentry revolve around the different ways to make a box. In your link, that large box on the bottom has some interesting things about it. It looks like the end panels are tenoned through the sides--is that right? I like the way you left them proud and chamferred. Also, the lower portion of the end panels are inset a bit--which precluded using dovetails. Is the inset to create a ledge for an upper tray inside?
By the way, thanks for linking us to the Daiku Dojo site up above! I was looking through your pages and found another great box. It's the one with double twisted dovetails and the wild grain pattern wrapping around it. I've linked to it below for the benefit of others.
Wiley
Bob Le's twisted dovetail box (at the top)
amelon
>Hi Wiley,
Yes, the end panels have through tenons. It's a style I've seen used by Makoto Imai and his students. The image below is Makoto's toolbox. The inset of the end panels is needed for the through tenons (to give it strength) and also to allow room for the handles (which are also slightly inset). The handles aren't designed for carrying the box a long distance since it's quite a strain on your fingers. The box is meant to be carried on the shoulder. I have photos for the whole construction here.
- Bob
Video of my version of Roy Underhill's tool box *LINK*
Roy Anderson
>I found these plans on St. Roy's web site. I later saw some very similar tool boxes on E-Bay, circa 1930, so this must have been a popular style for tool boxes.
I'm going to attempt to include a photo of the old version from E-Bay, which actually has the tool box laying on its back. It should be standing up with the drawer at the top and the flap going down in front. I'll also attempt to upload a video that I just made and put on YouTube showing my version.
I hope all this multimedia stuff works. Be sure to click on "My Tool Box Video" below the picture.
My Too Box Video
Pam Niedermayer, Austin, TX
>I bought a bunch of old Japanese tools which was shipped me in a Japanese toolbox, all very aged but still sturdy. I was told it was a cobbler's set, or a maker of wooden Japanese shoes.
If I were to pack it with tools, it would be way too heavy. I've often wondered why more of these aren't fitted with wheels on one end and a handle on the other.
Pam
Wheels, wish I had thought of that *grin*
Marv
Re: Wheels, wish I had thought of that *grin*
>It's a good idea. I have often used a wheelbarrow to haul tools, shovels, levels, paint, twine, etc, for fence building and stuff around the yard. Wheelbarrow with a wooden bucket would protect tools. Smaller, carryable toolbox could fit into it.
Wiley
Re: Video of my version of Roy Underhill's tool bo
Alan DuBoff
>This looks like it could adapt to my needs actually. I would like a small drawer. Looks a bit more involved to enclose it...I have an idea...(sound of gears making noise)
Thanks for posting that video, your camera worked perfect. A great tool to have in order to share. Thanks for taking the trouble for your first use...
1) makes me realize I do want a handle.
2) I like the drawer, and why I was leaning towards the popular mechanics box.
3) I have some smaller marking tools, pencils, pens, marking knifes, etc...that I will want to incorporate into drawer space possibly.
Cheers,
Alan
Alan DuBoff
>Bob,
Your very close to me, you probably work about 10 minutes from me.
I don't recall meeting your at the Bay Area Galoots, but there is a BAG-A-THON coming up soon, maybe you'll bring your toolbox. MannyH often shows up at the BAG-A-THON, you must know him from Jay's classes. There's a mailing list that one of the guy's runs, at this link. (click on mailing list tab)
I hope to get my timber shipped out west soon, and this project will become my full time hobby. The home will eventually move to here.
That said, you have me thinking about incorporating a top as on your toolbox, but on a carpenter tote. I have seen the octagon tote, it's interesting, but I would put a leather strap on your style first, I think. I need to hold long levels and squares in it as well.
Cheers,
Alan
Not bad, Wiley, might do that.
Look up "shooting cart" *LINK*
Dan Donaldson
>A lot of cowboy action shooters and others use shooting carts or range boxes that have large wheels. Or you could make something like shown in the attached link, but add a wooden tool box to it. Uses bicycle wheels, so it would be easy to push/pull.
cart
Here's the link to the plans *LINK*
Roy Anderson
>See link. Enjoy!
Roy Underhill's tool box.
What?!?!?
>They don't use horses?
Mike Fitterling
>Late. But here's a couple I did. The smaller on was for my son and the other is my own. Box-jointed, but could esily be dovetailed in stead.
How did you attach the bottom?
Alan DuBoff
>Mike,
How did you attach the bottom of the box? I see you have dovetails on the side, similar to how I was thinking, but how did you attach the bottom?
My plan is to dovetail the bottom also, rather than using a dado.
Cheers,
Alan
