7thcentury boat from junk *LINK*
redcoat
redcoat
>Here's a 7thC type curragh I built from junk found at demolition sites. VERY galoot in tools, materials and methods. Enjoy!
http://www.redcoatphoto.com/Patrick%20Project.htm
Boat from Junk
Re: 7thcentury boat from junk *LINK*
Wiley Horne--So. Calif.
>Justin,
That is an absolutely amazing accomplishment! Looking at the evenness and strength of that latticework, and the way all the pieces come together fore and aft, the word 'junk' would never come to mind. The finished frame is just stunning.
What kind of paint did you use, that would be waterproof? And how are the lengthwise pieces (what are they called?) joined to whatever they terminate into, fore and aft?
Wiley
redcoat
redcoat
>I found a 1 gallon car of off-white "scrubbable kitchen latex" paint= so it got 3 coats. Black, or brown, but that is what I found in the cellar of the demo job that week.
The longditudenal (my spelling is crap now) stringers are fastening in way unbecoming the fine joinery art of boatbuilding. Look close at the transon. You can see where I drilled a hole, then bunged a length of dowell through (4") about 2" inside of where the stringer ends, and running almost parralel to it, but bored in maybe 15 degrees off. I tightly boung the stringer to friction fit and glued dowell- sort of like lashing two stakes together. Crude, but it worked, and got ride of the need to cut a bunch of knees to fasten stringers to transom.
The front stringer come together and are joined by a breasthook (triangular bit of junk 1x8.
Take a read of the book Skin on Frame boats by Robert Norris. Worth buying, or getting local library to bu.
redcoat
FREE BLO
redcoat
>The frame was finihed in a litre bottle of BLO I found. The boat did suffer some design problems- like me designing it!, and it wasn't as even as it looks, but it mattered little in use
