Re: nice tools for carpentry?
ThomD
>I don't all together use the good stuff. I remember too well tearing all the crosscut teeth off a Ryobi while triming a solid core door. there were some staples hiding in there.
Another bad experience was to come home from work and find some workmen had used a very expesnive art grade Japanese chisel as a cold chisel in removing an oil tank. Not quite what you were asking...
Over the years LV has put a good sellection of japanese replaceable blade saws on for ridiculous prices like 10 bucks. I bought heavily so that I wouldn't have to worry.
Today I was doing a neat piece of carpentry, building a daggerboard for my trimaran, and I used my dad's Rali plane. It was probably more effective that an Hotley would have been, since those planes have the most easily calibrated blade depth I have every used.
My approach is governed by:
- I have a ton of tools, mostly good, so I can use just about anything I like without endagering my only good tools.
- I try to keep some proportion in mind, certain tools are probably only going to need a sharpening if the worst happens. Other, like saws, that can be destroyed will not be put at risk.
- I can do good work with cheap tools. Ultimately it is the user not the tools, to some considerable degree. So, if I have to dip into the cheap stuff, like the discount blades, they are pretty good, and I can make them do what I need.
