Sharpening the elusive $5.00 card scraper
Edward in Vancouver
>Am at wit's end. It only took me a week or so to learn how to put a decent enough edge on a plane iron to shave hair and make decent shavings, but a card scraper? I'm still at it and getting more frustrated, which makes me want to master it all the more.
I think my problems start at the filing stage. O.K. I got LV's "scraper set" for my B'day a few years back, file and file jig, holder, and variable burnisher. The card scrapers I use at work (chocoalte shop and bakery) are used to scrape clean the beech and maple topped tables,(suagar/caramel and chocoalte dry on hard, like glue, and no one likes a wet wood table) so a square clean edge with no hook works best, and these scrapers probably have rounded over edges from daily use.
1) I found I almost never got square edges when clamping the scraper in a vise and using the file jig as intended. There is an aprox 1" shoulder on the jig to guide the scraper and a relief channel just above the file. I found I wasn't filing a squre edge this way. I had better luck laying the jig on the bench and moving the scraper along the jig.
2) Stoning. I don't own any decent oil stones, but have an 800 and combination 1200/4000 water stones. And I found out the hard way that these are far too soft. By laying the stone on its side on the edge of my bench and guiding the scraper along the apron of my bench, I though I had a foolproof way of getting a 90 angle. Of course, I rounded over the edge, and scored my stones. How much pressure can or should you put on a waterstone?
3) Burnishing. Still haven't had much success with the variable burnisher. Alot of it has to do with clamping the scraper, my scrapers are only about 2" wide, and the burnisher sits about 1/3/4 high on the scraper, leaving next to no room to clamp the sucker in a vise. Try and experiment as I might, I can get some moderate shavings on soft maple, but more dust than shavings, irregardless if I put a 7, 10,or 12 degree hook. I don't own a "proper" burnisher --yet. I've tried the uusual stuff-- a wrist pin from a Volvo piston, with a diameter of somewhere around 3/4". The thing is hard enough for a hacksaw to skate over, but after studying any information I could get my hands on, the diameter is all wrong--too big. The burnisher in the LV jig is somewhere around 3/16" in diameter. I've got my "mayonnaise jar" saved up for the burnisher-- the tear drop shaped one, but which radius do you use for a card scraper?
I've got about 2 years worth of "pop. woodworking" and maybe a year's worth of "Woodworking" magazines, and I know Chris S. wrote a few articles about scrapers and sharpening, but can't find the article.
Can anyone direct me to some information about sharpening the elusive card scraper?
