Safety Week
Safety Week
Safety Week
Adam Cherubini, NJ
>Hey, it's woodworking safety week. Anybody got any good safety tips here?
I'll be blogging about safety all week but I have an extra. Get a brush for the shavings on your bench and use it. I've found my striking knife a couple times brushing shavings off my bench with my hand.
I promised the folks on my blog I'd compile their best tips for Saturday's blog. Maybe we should do that here too. Ellis. Do you think we could make a safety tips WC article? Maybe we can compete with the noisy side guys to see which forum could generate teh most number of (sensible) tips.
Shocking how many people hurt themselves working wood. This Safety week was Marc Spagnuolo's idea and I think it's a great one.
Adam
Re: Safety Week
Re: Safety Week
ThomD
>I think the most important safety tip I have learned over the years is to listen to the little voice. I've had bad things happen in all sorts of situations, and in most cases there was a little voice that warned me first. In hand tool terms it is normally telling me to quit when I am mentally tired. Unless I get trembly from exertion, the dangerous kind of tired is normally the mental kind. Part time woodworkers are normally doing stuff when they have already put in a day's work, so it is easy to be overtired.
The problem with the little voice is it warns you more often than bad things actually happen, so one tends to ignore it. Like Pearl Harbor, or 9/11, there are usually warnings, but knowing whether to take them seriously is the hard part.
The few times I have medium seriously hurt myself hand tool woodworking, have been with axes and knives. While I was a very experience woodworker at the time of both injuries, as an amateur one seeks out opportunities to do new things, and I goofed, and put my hand in the way of an overshooting cut.
While I generally think that the hand tool world is pretty safe, be aware that in certain regards hand tools are even more dangerous than power tools. Most power tools in a small shop will at most remove your hand, and most likely only a finger or two. There is a saying that a dull knife is less safe than a sharp, one. I think we know why that is said. But I also think whoever said it quite likely had never seen a truly sharp knife. A knife can very easily take your life, and the same is true of a chisel or axe. It would probably take falling on a chisel to get that unlucky, but be aware hand tools have relatively ulimited geometry, and can snuggle into the deep recesses of the body.
I had a Dirty Harry moment once in the workshop. There is a scene in one of the movies where he refuses to have his pants cut off by a doctor, and says "let it hurt". I once shot out my foot to stop a heavy plane blade from hitting the concrete floor. I didn't want to have to regrind it. I thought I got away with just a bruise until I heard the sqelching sound in the my shooe. I knew it was a dangerous thing to do, but it was my favorite Japanese blade!
Re: Safety Week
The best safety tip I know
Bruce, a MN Galoot
>came from Steve Lamantia, from one of his wonderful missives on the Wreck:
"Where's it gonna go when it slips?"
I'm so guilty of not paying attention to this admonition, I've had to make it a very conscious effort. My most egregious failure always has to do with chisels. I've cut myself three times with the same chisel doing the same operation, you'd think I'd learn. So far I've escaped serious injury, but that's merely by fiat, not anything I've done right.
Bruce
Re: Safety Week
Re: Safety Week
Pam Niedermayer, Austin, TX
>I was taught at a very early age that when a hot and/or sharp object starts falling, get out of the way; so I simply jump back. This is harder to do with spherical objects, was taught to catch balls.
Pam
Re: Safety Week
Re: The best safety tip I know
>'Don't cut toward anything you don't want to cut off.'
Stephen
Re: Safety Week
James Watriss
>Guy I knew went to the hospital to have his tenon reconnected after such a slip. Surgeon was amazed, said the chisel was clearly sharper than his scalpels ever were....
Guess that's what you get for using disposable blade scalpels.
Re: Safety Week
OT little voices
Adam Cherubini
>My doctor tells me to ignore the little voices. He says they are liars.
Re: Safety Week
Adam Cherubini
>One thing I think we need to do is not worry about what's going to happen to our benches. Mistakes I've made in the past have often revolved around me not wanting to put a mark in my bench. So I balance my work on some miserable unstable scrap.
Maybe we should be showing pictures of scarred up benches instead of these precious things that look like furniture. Work benches are not furniture.
adam
Re: Safety Week
Hand tools
roninkokomo
>Our side of the pond has a simpler time of it in this area, but the one rule that we often violate, which can cause loss of body fluids and even digits, is "Always keep all fingers behind the cutting edge". Have never lost digits, but I have been very lucky twice!
Once I got in a hurry and once I had a cherry rail implode as I was trimming a mortise.. 14 stitches that time.
Re: Safety Week
Safety first and all day!
Philip Duffy
>Things that go around fast, like helicopter rotor blades and pieces of wood on the lathe can hurt you very fast! After 30+ years in the Navy cockpit without a scratch I have had 2 violent accidents on the lathe; one my own fault and one where a piece of cherry exploded and nearly took my left arm off. Be careful out there, guys and gals, all day, every day. Philip
Re: Safety Week
Re: Safety Week - catching sharp objects
Ted
>I used to have the impulse to catch falling objects in my shop until I bought some of those interlocking foam mats that cover the floor. They don't cost much, less than the cost of a damaged chisel and far less than a broken plane. Once I covered my floor with these, I was easily able to stifle the urge to catch anything falling from my bench. I have yet to damage a tool falling from my bench since putting these down.
Fewer injuries, no broken tools, comfy feet, life is good!
I also wear heavy leather clogs in the shop which have yet to be pierced by a falling chisel.
Ted
Re: Safety Week
Greg B�tit, Crown Point, NY
>I always smile when I hear about people not wanting to mar their bench tops because I put the first ding on the Norm Vandal bench that was featured in The Workbench Book.
This is what your bench top will look like after a few years' use. This one was originally a 19th Century Stratford, VT undertaker/cabinet maker's bench. (13' long. The front board is 6 1/4" thick, 18" deep.)
Re: Safety Week
Re: Safety first and all day!
>What's with all this imploding and exploding cherry? What can you do to avoid such a thing?
Pam
Re: Safety Week
Re: OT little voices
roninkokomo
>I have a friend who hears them after some Wild Turkey
Re: Safety Week
ThomD
>The worst bowl accident I ever had was holding a bowl by the rim in a 3 jaw chuck to turn the foot. It was thrown violently over my shoulder and smashed against a wall 20 feet back. I guess the lesson there is to not stand downhill of it, and of course I have never held a bowl like that again. With exploding stuff you can sometime tape it. A huge safety improvement over the years has been the adoption of variable speed drives.
Re: Safety Week
Near Miss Reporting
David Miller from Iowa
>The best way to modify safety behaviors is constant, group diligence on recognizing safety hazards and focusing on safe behaviors. Incident reporting is valuable, but infrequent (happily) enough that it doesn't do the most good. Something that might work in this forum is if everyone reported, on a somewhat regular basis, their "near misses" - probably have 20-50 of them for every serious incident.
To follow up - some of you may recall I ran my dominant index finger through the table saw last fall. Mostly healed, still deformed, but can do most things. A couple things I can't do is fine work, like putting nuts on small bolts, and I used to be a damn good horseshoe pitcher, but that is gone forever now - I really miss that.
Re: Safety Week
ThomD
>There are lots of cutting actions that violate that rule. As long as the blade can't come forward as far as the flesh, it should be fine. Think of the drawknife.
Re: Safety Week
>A drawknife is a much feared tool. But unless you touch the very sharp edge and you don't get other limbs in the way, it is difficult to hurt yourself with a drawknife.
If you pull it toward yourself, you will notice that you run out of pull when it gets close to your chest. If it is going towards any other body parts you are using it wrong.
I have no problem putting a 20 inch drawknife in the hands of a child, at a shaving horse. I just tell them not to touch the sharp blade.
Stephen
Re: Safety Week
Alex Grigoriev
>There is a reason people wear a leather apron while working with it.
Re: Safety Week
exploding cherry
Philip Duffy
>Hi Pam, Don't really know the answer except that my 18in dia. bowl --chuck mounted - - had given me no indication of a bark inclusion under the "skin". I was about 8 seconds from finishing that bowl and it just blew up in my face. The doc at the ER said I was lucky to have had my face protector on but the half that came loose practically ripped the muscles off my upper left arm. I was out of action for 3 weeks. It pays to be safe but sometime you have to be lucky! Phil
Re: Safety Week
Re: exploding cherry
>Sounds like treadle and pole lathes may be not only cheaper but a lot safer.
Pam
Re: Safety Week
Ouch. Slower turning seems a good idea.
Re: Safety Week
Re: treadle & pole lathes
Glenn Madsen near San Francisco
>I'm not at all certain that these types are set up to handle an 18" or larger piece all that safely.
Big bowls, even when almost finished, are traveling pretty fast at the edge, even when the lathe speed is set low. And dealing with initial imbalance is going to be 'interesting', without some serious engineering and added weight to the structure. There's a reason big lathes are pricey.
Now, for spindles, table legs, pencil post beds, etc...
Re: Safety Week
What does a big, pricey lathe provide?
Re: Safety Week
heh .. heh..
I bet he was so proud of his sharp chisel that the injury was incidental! :)
