Auger Bit Question
Auger Bit Question
Auger Bit Question
David Brown
>As someone new to hand tools, I find myself with lots of questions. I have a brace, but only one auger bit so I'd like to get some. I see on the great auction site that you can get jennings pattern bits which look like someone twisted a flatish piece of metal into a screw or ones by irwin (and others, but most commonly Irwin) that have a solid center shaft with treads going around them. They are both screw tip bits.
Is one better? I also know you can get brand new ones at Toolsforworkingwood.com (Jennings pattern). Are the old ones (in good shape) better than the new ones, or are the new ones worth the premium price.
Thanks for any advice and I hope everyone is having a good weekend.
--Dave
Re: Auger Bit Question
Joe Rogers, Northern Virginia
>Dave the two types of bits usually are intended to cut woods of different density. The Jennings bits have finer lead screws so they don't progress as fast in the cut. The Irwin solid shank bits have coarser lead screws so they cut faster. Thus you should really look at the pitch of the screws to find the bits you want. The fine screws for hardwood and the coarse for softwood. As far as the quality, the new bits are good but probably more expensive per bit to acquire. Old bits may need to be sharpened to perform properly and if they have been over zealously sharpened before they may not have the metal left to rehab.
Bottom line if I could find vintage bits in good shape they would be my first choice.
JR
how about an expanding bit
Robin Corell in Atascadero CA
>I have a full set of Jennings bits as well as a couple of expanding or adjustable bits. An adjustable bit would be a great choice for a first bit. They are easier to sharpen and one bit will drill holes the size of half a set of Jennings bits. The down side of an adjustable bit is that they are more dificult to keep true in the hole ie. the hole can more easily become crooked or curved due to the lack of flutes. on the up side I have used this to my advantage on more than one occasion to drill curved holes for Romex.
Robin
