Got my tools somewhat organized
wilbur
>My bench building project went on hiatus when I realized I had made a miscalculation on the legs. It's just as well -- this hiccup gave me a chance to get my shop organized a little. My previous tool storage system consisted of cardboard boxes on the floor. Sometimes I would skip the cardboard box.
Besides, as I get into making the base, I realized that I would need more tools than I needed for the top. Looking back, it seems like the only tools I needed to glue up the top were a jack plane, a jointer plane, a square, a pencil, and clamps. For the mortise and tenon joints in the base, I'll need a lot more than that.
So here's a picture of what I did. I drilled holes in the walls of my basement and attached 2x4s with the flat side against the wall with concrete wedge anchors. I placed and shimmed pressure treated 2x4s on the floor of the basement so that the 2x4s on the wall were resting on the pressure treated 2x4s on the ground. Then I attached pine boards to the 2x4s, and then hung the tools on the pine board.
This clearly is going to be a work in progress for quite a while. I'm making a guess as to which tools I use most often, and tried to put them in the most convenient spot. I'm already second guessing the rack I made for my saws, as I have to lift the saws straight up which means that I lose storage space above the saws. If you look closely, you can see how I screwed up the chisel rack, as I didn't take into account that for my chisels, the diameter of the handle gets bigger as the chisel gets wider. I also want to redo the clamp rack, as the bottoms of the clamps sway back and forth a bit. I did make sure that all the various tool holding devices are just screwed to the pine boards, so I can move/replace them as needed.
But now I can start working on the base of my workbench!
