THE WOODRAT IS BACK!
How do you make drawer sides?
Patrick Gibbons, Katy, TX
>In the thread below I asked about which wood others used to make drawer sides. The conversation turned to thickness as the major concern. Assuming I wanted to make thin drawer sides, how should I go about preparing the wood and, once again, which wood is going to be easiest/best for the process? Should I have the supplier thickness the wood to 1/4"- 3/8" or should I resaw the wood or should I hand plane it myself? I do not own a planer or a bandsaw. I want to be practical here. On my to do list has been the making of a veneer saw to resaw wood. I recently resawed some eastern red cedar with a rip saw and it is a long process. But hand ripping sure makes a softer wood look better simply because of the work involved.
Re: How do you make drawer sides?
Wow! tough question?
roninkokomo
>Depends on what you want to do. I would get 3/8 from the supplier s4s.
But that is me. I can resaw with a bandsaw or my usual is a table saw- bandsaw combined deal. But if I new I could get stable flat stock from the supplier, I'd go ahead and get it at 3/8 and run a number 4 over it before finishing.
I do have a bowsaw that resaws pretty well, but it takes a lot longer.
Re: How do you make drawer sides? *LINK*
Dean J in MN
>I think the following passage from an article in Chipstones's American Furniture may be of use:
'The number of complex storage forms listed in the written documents and the evidence of the many surviving examples suggest that western Connecticut joiners employed a number of strategies to produce case furniture efficiently. Foremost was their reliance on local sawmills to provide boards in desired dimensions, thereby precluding the need to resaw or plane the lumber to usable thicknesses. In Newtown and Woodbury, surviving artifacts reveal the joiners� use of blanks that required only slight planing before use. Some boards used for drawer linings or backboards still retain their water-powered saw marks. In Newtown, most cherry boards were sawn 3/4" thick, and yellow poplar and oak, 1/2" thick; in Woodbury, cherry tended to be 7/8" thick, yellow poplar, 1/2 or 7/8" thick, oak, 1/2" thick, and white pine, 3/8" thick. With boards delivered in proper thickness, the joiner could more easily lay out and cut his joints.'
What is of interest to me -- the workers of the period had ready access to stock which required little "thicknessing." At least not the kind of thicknessing I hear being talked about. They had no need to take 4/4 to 1/2, or even resaw in the shop.
So, I would get your stock just as the old-timers did. Near the correct size for its intended use.
The complete text in in the link.
-Dean
The Social Economy of the Preindustrial Joiner
Hank Knight
>If I were you, I'd order 3/8 to 1/2" S2S Eastern White Pine, Sugar Pine or Soft Maple for drawer sides and bottoms. You can use about anyting, but these are my choices. I think resawing your own with hand saws would be quite a task and you would have to deal with the wood movement after you resawed it. Ordering it pre-thicknesses and surfaced saves lots of work.
ThomD
>I built a panel resaw thing and it was very tiring to use and at the time a little frustrating because I didn't yet have the skill to use it. Aside from skill the blades need to be capable of a dead fall through the wood, steering is pretty difficult with the wide blades one uses. There is often a fair amount of clean-up required if the saw even wiggled a minor amount. Reality wise bandsaws show up for next to nothing on Craigslists. I saw a 30 incher antique cast iron, for 700, which is a lot more than nothing, but that is one huge saw! I would figure you could find one for 100-200 of pretty good quality. If you live in a decent center you can find tablesaws for 20-40 bucks for real quality saws, so why not bandsaws. Any 14 inched can be set up to resaw 12" wood with a height block.
In your situation I can see a further reason to use pine. A classier option is mahogany, about as easy to work as pine, but better pedigree. I normally use maple for drawer sides, but it needs power tool prep. Depending on how deep you need the drawer sides guitar neck stock in mahog might be a good choice. Contact Stewart Macdonald. The mahogany I am talking about is not the junk from HD which is fine for certain things but certainly not up to the use you have in mind. It isn't real mahogany, and has a funny odor to boot. Drawers need some care in prep I would never trust someone's 4s job, by the time it got back to the shop it could have some twist. That will often happen naturally as wood settles down from resawing, or planing. So getting it oversize and gradually bringing it to shape with rests is the best way. Fits the nightly warrior timeline also. Pieces that are heavily milled and immediately assemble are often fine, or not, there is a little risk. Of course it depends on the ultimate fit one is after. There are some uber fits out there that defy common sense and would require museum like conditions to survive in working order. There is also stuff like drawer slides where there is an inch or more slop, so dimensions are pretty slack. What you can specifically get away with will depend on the history, species, and qualities of the wood; the conditions of the shop it was worked in; the design of the piece; where it ends up living; etc... So war stories about how someone did something and it worked out great are only as good as the specific circumstances.
Pam Niedermayer, Austin, TX
>Might be a lot of fun to make at least one drawer by riving the sides.
Pam
I resaw 5/4 quartered poplar
Bill Tindall, E.TN
>But then I have a band saw for resawing, and a planer for smoothing and a sawmill source for supplying the 5/4. If you are serious about woodworking, you need access to a planer. Is there a club in your area? For the time being you might be able to "rent" time on a planer by finding someone local that has one.
I don't find white pine pleasant to work. It is too soft for my taste. Actually a somewhat harder wood works easier. Soft maple is a good choice but it can be considerably more expensive than poplar so I wouldn't recommend it for that reason. But if I had a cheap source I would. And mahogany is way more expensive. I can't imagine using it for interior parts. It just seems a waste to do so.
Occasionally I accumulate walnut or cherry sap wood and I have used each as drawer parts.
shingles
Bill Tindall, E.TN
>Many of the pieces we examined in Philly museum had white cedar drawer parts. We were told they were made from what was then readily available riven shingles.
Re: shingles
>Yeah, but roof or siding? Do you know? How thick were they?
Pam
Just a thought.....
Wiley Horne--So. Calif.
>Patrick,
You know how, at the end of a project, you have a bunch of shorts and twisted boards, and cupped or bowed boards, and boards with sap, and boards with surface flaws or knots on one side? And you know how they build up, and take up room, but you don't want to throw it all out--just on general principles?
A thickness planer (lunchbox planer) doesn't take up much room. You can take the worst board in the world, flatten one side with a cambered-blade plane, run the other side through a lunchbox planer, let it sit a couple days to rest, then re-trim it in the planer.
This procedure can turn your pile of scrap into usable drawer bottom, drawer back, and occasionally drawer side material. It's fun to take 4, 5, 6 pieces of this stuff, and edge join them into a drawer bottom.
2 cents.
Wiley
I presume roof
Bill Tindall, E.TN
>They didn't say but I presume the raw material would have been split roof shingles which they then planed to thickness. I don't remember the thicknesses but I think it was greater than English oak thickness and much less than 3/4".
an example of your thought
Bill Tindall, E.TN
>This is a cabinet in the works (note room for expansion drawers) to corral clutter that accumulates around lathe projects. Even I have become exasperated with stuff piling up on the bed.
Visible are parts made from oak, birch, hemlock, cherry, poplar and walnut.
Relating to recent threads, the drawers and case are dovetailed because it is a way to get practice on a project where I can afford the risk of experimenting with technique. I am just a few drawers shy of 100 and I think when I reach 100 I will declare success in the quest to be able to make dovetails drawers.
Thanks, Bill.
Sweet jeez...
James Watriss
>A lot of people buying from the supplier at thickness in here...
Problem I see is this. In many cases, the suppliers are getting in pallets of 4/4 and thicker. If they're selling you 3/8 or 1/2, chances are very good they're milling it down themselves... and charging you for it. It's a specialty thing. Maybe that's just me, I suppose it's possible that there are mills locally that will mill thin stock like that, but thinner stock is less stable in general, less hardy, and more prone to checking, so it's not ideal for transportation purposes... ie, what they'd have to do to sell it to resellers.
Buying drawer sides from luthiers is one way to go, I suppose... but seems a bit pricey to me. They'r edrawer sides, not sound boards... they don't have to be so perfectly selected or straight grained.
I think that, in general, like so many other things... making your own is the best bet. But one way or another, it's going to require a small investment. Or, you could spend the extra dough every time to have them waste a lot of wood away.
-As someone said, used band saws pop up frequently on craigslist and ebay. As tools go, these will take up the least amount of floor space, and once you learn how to use one properly, you'll find you can do a lot with just a little.
Resawing wood is a VERY handy skill. Milling down 3/8 or 1/2 from 3 or 4/4 means you're wasting a LOT of what you just paid for... and it's what I was taught in school. (schmucks... they cost me a lot of money that way) Better off looking for a 12/4 or 16/4 board in the shorts bin. In general, it's wider wood, with fewer knots.
Resawing wood also makes a lot of sense for frame and panel projects. I've seen a lot of F/P chests and things with very thick, heavily rabbeted or chamfered panels. Chamfered panels are great if you're riving stock, and one side comes chamfered out of the log. But if you're resawing from a heavy board, you only need to resaw panels to be just thicker than the grooves.
There's a small learning curve, but it's not too bad. Rule one, low tooth count. Rule two, learn to play with your upper wheel alignment, and get used to the idea that sometimes, the best test for how straight the blade is cutting is to see how straight it's cutting.. not to look at where it's positioned on the wheel. If the wood is drifting away from the fence, the blade isn't cutting straight. If the wood stays on the fence, but the blade is wandering away from the fence and farther into the wood, it isn't cutting straight.
-Shakers used to have drawers with tapered sides on them. It would take some learning, but I bet if you looked around for some clapboards, you could make them work in a similar fashion.
-Buy a bandsaw blade, and make yourself a bowsaw. Make sure there are very few teeth per inch, so you can cut quickly. Again, learning curve. But resawing, even by hand, is a huge cost savings.
-I don't know what you have or don't have in terms of space, neighbors, tools, or budget. Lunchbox planers, are ok, they require a good shopvac, with a good filter, and no neighbors. In conjunction with a good cambered jack plane, they may be all you need for general milling. Jointers are nice, but the mill marks they leave look essentially like smaller jack plane tracks... you just need the board to have a side that's flat enough to slide gracelessly through the planer. That, and a good used bandsaw, should cover a lot of ground for you.
-Pallet wood. decent secondary wood in that it's cheap. And lately, pretty thin, too.
-Buy a good used handsaw that's long and has very few teeth per inch. Don't look for a smooth cut, look for a straight one.
And so on. I can think of a handful of jigs that might work... you could conceivably make a sliding arrangement to use a circ saw to do cove cutting, for instance, and use that as a power scrub plane. But if you're not used to jig building, and the general safety stuff that is part of the course of good jig building, then suggestions like that may not be the best thing for you.
In general, I don't like to pay any more to the suppliers than I have to. In that vein, I think that further investments in tools will pay dividends for you over time. That said, I do understand if you're more interested in cutting joinery than in milling wood with your spare time.
Well stated James!
Scott Burr in Ben Lomond, CA
>All said and done, I look to the bandsaw...
Re: Sweet jeez...
>James, I agree. I am somewhat shocked that so many buy pre-thicknessed boards. I thought woodworkers, especially experienced users, would thickness their own.
A bandsaw is the most important powertool in my workshop (I upgraded to a Hammer N4400 about 6 months ago and I am in Heaven!). I have just purchased a thicknesser and a power jointer for all the salvage Jarrah I have, but for years I have relied on a jack or a scrub plane. Or just used what thickness I had and built around it.
I like thin drawer sides and even thinner box sides. These can range from 1/4" to 3/8". My strategy for avoiding warp after re-sawing is to stack all the re-cut boards and clamp them between a couple of hefty flat and straight uncut boards. Lots of clamps. I have left boards like this for a couple of weeks and they have been flat and ready for final smoothing.
I cannot believe that everyone only has smoothers and jointers.
Re: Sweet jeez...
Dean J in MN
>I wish I could purchase stock near the correct thicknesses -- but I can not. I agree it seems a waste to have the lumber yard run 4/4 through a planner to get 1/2. So I resaw to get my stock.
But, it seems this is an ineffective way to work. Yes, it works just fine for me, I'm just a hobby hacker and time is not money. However, if time was money I would let the professionals/specialists do the initial stock prep. Sawyers had the specialized tools to cut large stock, in the period I was referencing they weren't taking 4/4 to 1/2 by turning half of it to chips. I suppose the reason I can't regularly buy 1/2 secondary woods is there is no commercial demand, which makes perfect economic sense to me. So, I put on my sawyer hat, resaw my rough lumber and stock myself with thinner stock. Depending on how well I resaw this may mean I can skip my fore plane and start final prep with my try plane.
-Dean
Re: Sweet jeez...
James Watriss
>I don't know that it's so ineffective. True, sawyers used to do it, but they also shipped by wagon, to more local tradesmen, not by UPS to god knows where, wrapped up on a pallet and going from one weather extreme to another in a matter of days, instead of months...
I don't resaw 4/4, I use thicker stuff. 8, 12, 16/4... it sits more easily, and yields more than 4/4 does.
I forgot to mention one more thing about resawing... especially with bigger stock. Because the outside has dried more than the inside, typically there's a lot of tension on the outside. So a very thin slice off of the outside, which will warp in both directions almost immediately, seems to be the ticket here. After that, the rest will stay pretty flat, as both sides are being exposed to the air at the same time, more or less.
Buy a chunk or two of 16/4 poplar, and become your own sawyer... saw up a stack that's cut to just over 1/2", and run them through the planer to skim off the saw marks. Stack, sticker, and clamp to let them dry for a while, and you'll have a small supply on hand for drawer sides.
It's only ineffective if you have to stop every time to cut new drawer sides. If you do a batch once in a while that will last you, it saves a lot of set up and lumber tripping time.
Re: Sweet jeez...
Dean J in MN
>James -
I agree. Best to be your own sawyer and stock up on thin stock. Resawing is far more efficient that trying to reduce thick stock to thin stock with a plane! Riving is an option for some as well.
-Dean
Bandsaw heaven
James Watriss
>Clearly mine is not the typical case in here... but I'm with you... I'm in my own bandsaw heaven these days.
On the right is the new to us Yates American 36", with a 20+" resaw capacity. Clearly not for everyone... 9.5 feet tall, 3 phase 240V...
In the middle is a Laguna 18". It has a great low table, resaws up to 11.5", and it's a great all around bandsaw. Runs on single phase 220-240, which is what most folks have in the basement for their dryer.
In the background is my baby 14" powermatic. It has a riser block, and was retrofitted with a pin guide for pattern cutting. I used that yesterday for cutting out a milk crate full of push sticks.
Obviously I lose any home shop cred at this point. But I did get started in the basement. If I had to downsize and go back to that, I'd give up my Sawstop tablesaw in a heartbeat, and keep the Laguna. Band saws take up so little space, and they can be tuned to do so much... and more safely than most tablesaws.
why 1/2 isn't sawed from logs
Bill Tindall, E.TN
>The saws that turn logs into boards saw a huge kerf, 1/4" for a circle saw and 3/16 for a typical band mill. This would be a mindless way to make 1/2 lumber. Planing the rough 3/4 to get 1/2" would be similarly wasteful.
If your furniture factory needed 1/2" lumber it would be obtained the same way we do it- resaw. There are band saws made just for this task and 12" wide stock is no more challenge to saw than 2". I used to take my lumber to a factory and have them resaw it. These band saws have feed rollers, and narrow kerf blades, and they saw at a breathtaking rate compared to what we can do. Stuff quickly comes out wonderfully smooth.
I'd love to see a better pic
>It's my eyes or your pic Thom I can't see dick.... How 'bout another one? I wanna see it!
Ditto Scott's comment...
Victor Parisian
Re: Bandsaw heaven
Marv....... Northern California Lake Co.
>James,
Your shop is just waaaay too clean! I want to see shavings and sawdust on the floor. Either that or carpet the place.
Marv
What I did for now
>I needed thin stock for other than drawer sides. I had the mill take 4/4 stock down to 1/2". I can't see buying a $500 bandsaw for $50 of wood. Let's throw in a $400 planer to do it the way others have suggested. My mill charges me 15 cents a board foot to S3S the wood. If I buy 2700 bdft I've paid for the planer. Oh yeah, I need to have a dust collection system. Maybe another $300. So another 2000 bdft. To justify the bandsaw also we're up to 8000 bdft. That's without blades, maintaining them and putting up with noise and dust. Hmm, but I wouldn't be wasteful with the wood and would save the cost of all that wasted wood also. So far in my woodworking I've bought about 60 to 70 board feet of thin stock. I think I'll make the veneer saw afterall.
