More mortise and tenon
Wiley Horne--So. Calif.
>Hi All,
This is a detail in regard to M&T joints. What is the best practice about using a haunched tenon? Always? Sometime? How do you decide? What is trade practice?
Thanks,
Wiley
>Hi All,
Thanks,
Wiley
Re: More mortise and tenon
Warren in Lancaster, PA
>One of the most common reasons for the "haunched" tenon is to fill up the gap left by a groove in the stile, as for a frame and panel door or a chest. This is commonly seen in period work. It is occasionally used with a very narrow rail where the tenon is not very wide and the haunch helps resist twisting forces.
Sgian Dubh
>Traditionally the haunch, specifically the square haunch filled, for example, the groove in the stiles of doors into which a panel fits. I was taught that it developed primarily because hand tools used to make grooves ran right through to the end of the parts. The same reason for using it exist today especially if the groove is worked with a spindle moulder-- that's a shaper in AmerEnglish. Spindle moulders work grooves in much the same way as the old hand tools in that mouldings generally run the full length of the part.
If making an M&T for a rail and leg where the rail face is flush with the face of the leg in, for example, a table undercart, the haunch's primary purpose here is to keep the upper third of the rail flush. The lack of a haunch in this situation means any cupping in the rail is more likely to reveal itself through misalignment on the show face. Where the top of the leg is hidden by a table top a square haunch gives most support. Where the top of the leg is exposed, eg, a front chair leg, some designs call for the sloping haunch, but this version is somewhat less supportive.
Where the show face of the rail or member is inset from the front face of the morticed member then a haunch is frequently dispensed with, particularly if the tenoned member is wide. Here the haunch doesn't add much to the strength of the M&T joint itself, it is not needed to fill a groove, and there is no need to ensure the show faces of either part remain flush. Similar considerations come into play even if the show faces are flush, but this fact is disguised by some sort of detailing at the intersection of the two joint members, eg, a chamfer worked on the end of the tenoned member along with a chamfer worked on the edge of the mortised part.
That pretty much sums up the trade practice I learned thirty odd years ago, and still largely adhere to today. It is also British trade practice, and I suppose different areas have different traditions. I certainly found the Americans did things differently when I lived and worked there as a furniture maker, but I don't recall their thinking on haunched M&T's varied much from what I'd learnt. Slainte.
Undercart, you say?
Joe Shelton
>Rich,
I always enjoy your comments on two levels. Your tutelage with regards to the craft is great, and your literary bent is fun, too.
Now, recalling your allusion to AmerEnglish, is the term "undercart" idiomatic of ScotLish, or is it Celtain?
And what is a sloping haunch?
I infer you're no longer in Houston; did the humidity get to you?
Joe
Oooh! Oooh! Teacher! I can answer!
Bill Houghton, California cold in Sebastopol, CA
>I think Sgian/Rich means by sloping haunch a haunch that angles away to nothing at the end away from the tenon - imagine cutting a groove in the stock that gets deeper as it approaches the mortise, and replicate the matching shape on the tenoned piece.
Another, cuter but less obvious term is "secret haunch." Charles Hayward used this term in "Woodwork Joints" (copyright 1970); the scan below, from this book, shows the sloping/secret haunch not very clearly toward the bottom right.
Re: Undercart, you say?
Sgian Dubh
>Undercart? Hmm? Not sure. I may have invented it myself.
Yes. The heat and the humidity got to me. After ten years I moved back to Blighty.
Here is a sloping haunched M&T. Slainte.
