A manly chisel!
Bill Tindall, E.TN
>I tossed that out for Pam....I must admit that a more dainty Japanese style would be nicer for the tasks but this one cost but $5 and 45 minutes of work. Recall that I am exceptionally frugal.
Someone brought a box of old tools to the club meeting and in it was what became this chisel. It is the sort of thing we used to weld to a piece of 1" pipe and chop holes in the ice for fishing. Anyway this thing was sharpened as a lathe skew chisel. The manufacturer is Riverside, a name I never heard of, but it is excellent steel.
I have been needing a wide flat chisel to use with guides for paring things. For example, to make the miters in this cock bead I shave them using a 45 degree guide black. Ditto for sliding dovetails with a 14 degree guide block. A wide flat chisel gives good register on the guide block.
First I ground away the skew angle and then established a bevel using a 36 grit wheel. I suppose because of the mass there was no tendency for the edge to heat. Also I was using a very friable wheel. Next I straightened the edge with a coarse fixed diamond stone. It took but a few strokes. The edge was refined with a fine diamond stone followed by the usual honing. I bought this thing because it had no rust. It was a simple matter to flatten the back with the fine diamond stone.
The tang is enormous. I drilled stepped holes in the handle, starting with 1/4" and ending up 1/2". I then sawed a slot in the part of the handle under the brass ferrule to further accommodate the widening tang. I was not confident of the handling so I used a scrap of sap cherry. It turned out comfortable, so I won't change it any time soon. I like this handle style. It works well and had good balance for what could have been its unwieldy size.
