the finish schedule
Bill Tindall, E.TN
>I followed the recommendations of Fred Stanley for the stain and Alf Sharp for the rest-both SAPFM Cartousch winners and obviously expert mahogany finishers.
sand to 400 to burnish wood some to control dye take up
spray wash coat of 0.75 # shellac
Sand 400
Spray Mosser's Analine dye #1500 medium amber maple 1 oz/qt. water. I coated to where the wood was damp after spraying, but not wet to where any surface water could be wiped off. Dry with hair drier.
Repeat with Moser's W1320 Dk. Antique Sheraton. Dry with hair drier.
I got very little grain raise.
Flood with linseed oil and lightly wet(oil) sand with 600 grit wet or dry paper. Let oil sit 30 min and then wipe excess off.
Let oil dry 3 days or until odor is gone indicating cure.
Spray with garnet shellac, 1.5# cut in 90/10 ethanol/isopropanol. The isopropanol was necessary to slow evaporation and keep the film wet. After 2 coats sand with 400 grit. and then coat twice more.
the oil really brought out the depth in the figure. I have a test piece I am finishing ahead of the doors. I am going to experiment with a dark glaze. Finally, I will rub the finish out with 4/0 wool and wax.
