We value your privacy.
>Ok, so I carefully craft some 3/8 inch diameter pegs of the correct length and drill my 3/8 inch hole in the proper location only to discover to my horror that the pegs are at best a loose fit. What now?
What size peg should I shoot for if my sharpest 3/8" drill,or any other drill of the correct size is used, and the holes are oversized?
>You can try to size your dowels down to fit the hole. If you have a doweling plate that is a cinch, if not you can make one with some acrylic plate, or thicker plexiglass or aluminum bar stock. Drill a series of progressively smaller holes to bash your larger dowel through until you have a proper sized dowel. That's what I do. Good luck.
>This happened to me once. I sawed the dowels in half and made a thin wedge to fit between the halves, so I wound up with wedged doweled M/T joints.
What I have done since then was make drawbored M/T joints. Offset the holes in the tenon and the mortise by a little bit so that the peg draws the joint tight, so that a loose fit really can't happen.
>Good idea. do you glue your dowels in? I think with the gap I see, I should be using an expansive urathane type glue to fill the gap and provide holding power.
Regarding making my own dowels, I'm tuning mine out of some straight grained oak on a little bench top lathe. Kind of fun, but takes forever to do total of 24 pegs of varing lengths. I don't have anything on hand to make a dowel plate with at present.
So, I am going about it by trial and error, as the drill seems to make a somewhat oversized hole.
>Almost all the pins I have removed from old pieces were mildly tapered their whole length. Either eight sided or four sided or round. The advantages of tapered pins are that they can engage the "drawbore" offset more easily (wedging action), they can be driven in until they are tight, and they can be removed easily by pushing from the back.
When I am turning things to go in a hole I make a sample hole first to use to test the first one or two turnings at least. When I do turnings for someone else, I have them send a hole made with their bit. I would set the undersized pins aside for another job and make new ones.
>This task is similiar to sizing a M&T joint by the width of your chisel. You make one to fit the other. It sounds like your drill bit may be a bit undersized. I have had this happen to me. I have a LN dowel plate and the only bits I have that will bore a hole with NO gap using the LN dowels are Russell Jennings bits that I use with a brace. If your hole is oversized drawboring will not close a gap.
Try another high quality drill bit.
Another trick is, if the pins go all the way through, put a piece of hardwood under the pin, then cut it about 1/16" proud on the face. Using a steel hammer peen the pin until it mushrooms to fill the gap.
Use hide glue, liquid or hot, it will best hide any gaps that are left. Good luck,
When you yank out an old trunnel, are they obviously 4 sided or octagonal? Is it possible some were originally round and have become 4 sided due to shrinkage and/or compression in the hole? What's your sense for this.
>The wedged dowels I glued in. I also put glue on the pegs for drawbored M/T joints, but I think that is more to make me feel better than anything else.
If you are turning your dowels on a lathe, you could also make them a little long and with a slight taper. That way, they'll have a tight fit.
>Adam, I don't want to get dogmatic about this as there are lots of variations. But often you can see that they were made with a chisel and that irregularities like a side out of square or a side wider than the others, a careless angle, remain visible when the pin is removed. Sometimes if you mix up the pins you can tell which hole they were in by matching the irregularities or size et cetera. Sometimes the pin is obviously deformed by going through the hole and sometimes the hole is deformed by the ridges on the pin.
As always there are differences in time and place and individual workers.
Mission accomplished. I turned the pegs slightly over sized on the lathe, trimmed off the ends with a sharp chisel then tapered them very slightly on the drill press with medium sandpaper.
Slathered the joint with glue, got a bigger hammer and whaled away at it. Actually a bit more care than that, but you get the idea.
>I've found the dowel plate significantly easier to use. Not sure why anyone would go to the trouble of whittling and peg and hoping it will fit.
I suspect if one had a good riving knife (which I think you have, Warren) one could riving good squarish pegs that need little or no further whittling.
>I've done the whittling route as well. What is clear is that I stink at whittling! The dowel plate gives me consistent results. I do "sharpen" the ends of the resultant pegs with my knife to make them tapered as Warren has mentioned.
My dowel plate is super hi-tech. I bought a chunk of mild steel about 1/4" thick and drilled holes, used a countersink to relieve the underside a bit and called it finished. I'm sure a proper plate with holes punched and steel hardened a bit more that mild steel would be even better. But, in practice my plate works just fine, just get a bigger hammer or drill a new hole when one gets too dull! (One does quickly learn you should rive the stock you try to hammer through my dowel plate!)
>I don't think the style of pins has great importance either esthetically or mechanically. As I mentioned above, there are several minor advantages to a full length taper. I think it is easier to make square or octagonal pins than to make dowels, especially in small sizes.
I examined an 18th century ladderback just now-- the pins were nearly square with a slight taper front to back (5/32" square). I have seen pins that were round on the show surface, but I am not sure they were dowels.
Seems that the one hole I was test fitting my peg into was wallowed out for the first 1/4 inch or so, and the peg I had selected was slightly undersized. Rest of the job went like clockwork - albeit with a heavier hammer...
Victor - still grinning like the village idiot at the results.
