We value your privacy.
>Is it acceptable procedure to dovetail the joint on the back of a corner cabinet? The two side boards are coming together in the back in a 90 degree angle and it is 63" long. Has anyone ever built a corner cabinet with dovetail joinery at this point or would something else be used.
>Presumably the grain of the panels that form the corner run vertically. Assuming that is the case then dovetailing the panels together is a weak construction because the root of each pin and each dovetail is short grain.
A tongue and groove or variation on that theme, eg, full rebate, glue and nails/screws, or even dowels is a better choice of joint. Slainte.
>I have braced bookcases and such with tranverse dovetailed braces. The problem would be if you used a larger element it could end up introducing expansion issues. This is why backs are often panels since they employ similar grain orientation to that of the case. Anything could be worked out, but possibly not simply.
>The backs of corner cabinets were commonly not a right angle joint but rather like a truncated pyramid with about a 6" flat. This helped to minimize problems when installing a corner cabinet in most corners that really aren't at 90 degrees. If the parts weren't just nailed, the dovetails were pretty large.
>Something else to think about is that nearly all corner cabinets have side panels angled at between 91� and about 93� to accommodate out of square room corners, even if there is a short connecting piece at the back corner set at about 136� from the inside face of each side panel. Slainte.
>now those two posts are some of the best tips I have seen in a while. I design a corner cabinet, you just know the first one would be at 90 degrees with a complete back corner, even though I know damn well my walls aren't friendly (I did the trim....)
>Ah Victor, Houston. I remember that armpit of the USA hell-hole only too well. I don't miss the climate at all. After ten years living in the place I couldn't stand it any longer and moved somewhere with a more equitable climate, ie, Great Britain, ha, ha. Slainte.
>I have seen several old corner cupboards, the back corner with a rebate and nailed or t&g and the corners are 90 degrees. To deal with the vagaries of room corners, the faceframe overhangs the sides, so fitting into a corner that is not square isn't a problem.
>I thought I would add a few details. Generally the parts are nailed together. I make the shelves first and nail pieces to them. A common design has six sided shelves. To visualize, start with a square and take off one corner diagonally about 3-4" long (back) and the opposite corner much longer diagonal side for the front. At the very back is a vertical spine about 1" thick which is beveled so that the backing boards (1/2"thick) can overlap the spine when nailed on to the shelves. At the sides are vertical boards(7/8"thick) which are rabbeted at the edge so the backing boards don't show and beveled at the front to meet the face frame.
I also use slightly more than 90 degrees. It is nice to make a large cabinet in two pieces, top and bottom.
>Hasn't changed much since you left. More traffic, more people, unregulated growth. Lots of $$$ to be made. Looking forward to retirement somewhere else (Northern Wisconsin, UP Michigan, Arrowhead of Minnesota ?) where they actually have four seasons.
But, the sun is out today, and the heat hasn't turned on yet, and humidity is relatively low, so about 20 to 30 days a year like this make it bearable.
Back to the shop to try to complete my Roubo bench today.
>In North American English, "rebate" means you buy something and, if you remember to fill out the form, cut off the universal product code zebra stripe, and mail with a lock of hair from your first-born child, you get money back.
What term do the British use for that, or are they smart enough just to discount the price to start with? Or does it all get absorbed in VAT?
>Victor, in the ten years I lived there I don't ever recall a pleasant day that occurred between about the end of March and somewhere near the end of October. I found the months during which pleasant weather occurred were late autumn and winter months. The rest of the year specialised in being miserable-- in fact I called the time between March and November the 'Misery Months', ha, ha. Slainte.
We are not below sea level here. Just googled it and we are somewhere between 39 feet and 49 feet above sea level. Business is great here, and I'm not in anything that touches the Oil Business. Over the years I have met few Houstonians who want to stay here after retirement, but there sure seems to be a lot of retirees in the on the golf courses and club houses.
I''m sorry my comment sounded disdainful. It's really not. One of my old-time favorite Texas politicians was Bob Strauss. I was using his pronunciation and it was intended warmly. Also, some of the Nation's most vital infrastructure and commerce is located along the Gulf coast from Houston over to New Orleans--such as the Gulf of Mexico oil terminals as well as the ports for grain sales from the entire midwest. With all that basic industry located there, it's no mystery why many, many people choose to make their homes there. Also no mystery why a homesick Brit would leave and get back to his roots! You're a good sport.
My wife and oldest son are both in the oil business.
If you are bored and want to see something interesting, google the Houston Ship Channel it will bring up the ship channel bridge (I610 East) Go to maps and satellite view. Zoom in and follow it out to Baytown on the east and then back to almost downtown Houston at it's Western terminus. Very impressive. While you are at it check out the downtown business district just a little further west.
Wood working connection... Oh ya, they bring in a bunch of Brazilian made chipboard/plywood that comes from managed forests in Brazil and it is about as cheap (read as crap) as anything you can possibly imagine.
>Maybe you guys have piled up 50' worth of dirt from all the canal digging? :) I was actually speaking more about the early 1800's when the capital was moved to Austin.
I've spent quite a bit of time in Houston on business; but the negative decision was made on two motorcycle camping trips. In both cases, the heat, humidity and filth were extraordinary; but on the second trip we camped in Sam Houston (or maybe Austin, can no longer remember) state park west of town. At 2 am it was 102�, in the woods!
