Re: OT - Auto Radiator repair
goodolboy
>Most threaded holes into an automotive type radiator should have brass plugs/fittings available to fit and seal them. (You MAY get lucky and just be able to use an extra radiator drain plug temporarily if it's the right size, but a permanent fix for any extra holes is usually a much better idea.)
The first step is to be sure of what the extra hole(s) drains, is it water or transmission fluid that would come out of those holes? If it drains water you'll need a more secure (higher pressure) fix than if it's transmission fluid (lower pressure). Best is to use a brass to brass connection when possible (if it's a brass tanked radiator), because you'll be able to get it apart later if you ever have to, and using similar metals that expand and contract more uniformly in response to heat and cold makes leaks less likely down the road.
Sealer or Teflon tape might be necessary on the threads, if it's not a tapered thread, but go slowly when tightening things and don't use any more pressure than necessary to make sure it doesn't leak, it's VERY EASY to crack loose a soldered-on or screwed-in radiator fitting by over tightening it.
Older type hardware store are a good place to look for smaller brass fittings if you can't find them at a NAPA type automotive store that has a large selection of fittings.
Home center type store are sometimes WORSE than a waste of time because in this case you really need to know what STYLE of thread is involved and a lot of minimum wage people working there won't know or even be able to SEE the difference between the right one and the wrong one, and you could possibly end up with stripped threads. Take the radiator with you to be sure of a snug and proper fit. With new fittings, they should snugly engage at least a few threads with finger pressure alone if it's the right fit.
