We value your privacy.
>top glued up last night. Didn't realize I had that many long clamps.
Now comes the fun part of flattening that top. Sort of looks like an aircraft carrier has docked in my shop.
I'm going to start with that old #8 Bedrock with a hock blade. Last time I was using it I was getting some tear out. I'll sharpen the blade as best I can, set the mouth on the tight side, start with very light cuts, and angle the plane into the work. After that I'll open the mouth as needed and take more aggressive cuts (to a point - if possible) as the work progresses. If that Ain't working I guess I'll try the LV bevel up number 61(?) and see what that does.
Any other suggestions would be appreciated.
More later,
Victor
Re: Finally got the two halves of my Roubo workbench
Wiley Horne--So. Calif
>Congratulations Victor!
Just as a suggestion, you want to start off with a cambered blade long plane (try plane), and then smooth. If it wuz me, I would put some camber on the 608--don't redo the whole blade, just hone some camber onto it. If you have a No. 5 or 6, that would be useful too with some camber. Start off with the 5 or 6 and work the whole bench going straight across the short axis of the bench (like crosscutting), then swing gradually around to diagonal--do the diagonal from both sides, so you don't get a low side. As you work around to the long axis of the bench, transition into the 608 and plane from the middle of the bench out, knocking down any high places in the middle first, and as the plane stops finding shavings to take in the middle, lengthen the strokes until you're going end to end. Until flat.
At this point, with the bench about flat, switch to the LV plane and smooth it, taking care of tearout at this stage.
2 cents.
Wiley
ThomD
>Depends how bad it is. If it's rough, as it can be if the current surface is as sawn, or has distorted during drying or has laminations that are not in perfect planar form, then I would far rather level it with the coarsest plane in the shop. The jointer is really a longitudinal molding plane. I don't use them on large surfaces necesarilly, remember that for finnest accuracy, which is what one needs in a bench, the machinist would use a scraper which is a small tool, with unlimited cutting geometry. A metal jointer is a very heavy tool also.
Dean J in MN
>As others have said -- depends on how "bad" it is. If the glue up is really close and the surfaces are pretty flat your jointer working across the grain is a good start. If you need to remove any amount of material start with a fore then move to a try plane. Get out your winding sticks and see what needs to be done.
No need to pull out a smoother, a really smooth bench is hard to work with. Flat is good, smooth isn't necessary or even desired. My benchtop, when viewed in raking light, still shows evidence of the camber of the blade I used to flatten the top.
-Dean
Bjenk Ellefsen
>Not much else to add, really. I am doing my top at the moment. Granted its a Nicholson top so its not assembled the same way. My top is two 2X12s glued on one edge.
Perfection is not required. Make yourself some long winding sticks and like Dean said, attend to what's needed. If tear out is not too sever, don't worry about it. I'm using a Try as I don't have a good wooden jointer yet. No complaints so far!
>Hi Victor,
I feel your pain. Can you take one more preachment? If not stop here. But anyway, here it is.....just my personal experience...... One of the main causes of getting worn out doing big flattening (aside from the fact that it's real work!) is uncambered blades. Yeah, the 608 is heavy, but the bench is holding it up. But you and your back are having to push that 2-5/8" blade through the wood. No point steering you toward a woodie, because you've already got that plane. But it is remarkable, amazing, stunning, and incredible how much easier life can be with a cambered blade in a try plane.
Wiley
John Aniano - in NJ...
>Victor,
How wide did you make the top for your new bench? I'm planning on an ~20" wide top because that is the width of the oak plank I have for my French bench. Any day now I'll begin making it...
Are you following any particular plans?
John
>Wiley,
I fully agree. I camber the Stanley 102 plane blades for roughing out the very hard pernambuco and other tropical woods I make bows from. The cambering really does reduce the effort! Of course, rubbing the whole plane sole on a slab of canning paraffin also helps!
John
Parisian, VL
>Thanks for the comments John.
The top is made up of Southern Yellow Pine (SYP) (construction lumber) 2x12's which I ripped and milled to 4-5/8 x 1-1/4 (=/-) x 8' Finished size is 24" wide by 7'9" long by 4-1/2' thick. I could have gone the full 8' in length, but some of the wood had badly located knots etc.
I am pretty much following Christopher Schwarz's design from his "Workbenches" book.
This is a fun project, but I've had many interruptions over the past few months so it is getting old now. I feel the need to complete this thing so I can get on with my life.
One of the problems was clamp time. Chris warns the readers in his book that SYP takes a minimum of 4 hours in the clamps. Another problem was the wood itself. I pretty much had to take the best of what was available - all pretty crappy stuff at the borg. Even 2x12x16s were not all that clear, and most were crooked as a dog's leg, and a lot was cracked as if from falling to hard in the forest. Also got some with some spalting going on.
Base assembly is almost complete. Now to line things up and make some massive mortises.
Camera was stolen in San Antonio last Friday, so no pictures for now.
Victor - making progress in Hot and Humid Houston
ThomD
>The first commercial job I got around 1982 was a table, and I flatened it with a jointer, a Record 07. Never made that mistake again! Not only are they heavy but they are sticky. I use wooden planes for that reson, about 1/3rd the weight, and I keep the jointers for the joints. I was looking over a piece of red oak on the hoof today, and I was seeking images of benches dance in my mind. Now that is some heavy dangerous, labour, getting them out of the tree in one pieces.
