How to sharpen with "one" grit size
Bill Tindall, E.TN
>Do you suppose if we coined a name like "Speedy Sharp" for this porcess someone would then sell cast iron plates?
I'm not counting the 80 to 120 grit on the grinding wheel which is done occasionally.
Indeed it is not only possible, but best, to go from the grinding wheel to 1 micron diamond (or 3 or 1/2 or what ever your pleasure) and be done.
Step 1. Hollow grind the tool. Wash and wipe to remove any contaminating grit. If the edge is straight proceed to step 3. A crowned wheel makes this task much easier.
Step 2. While learning to grind on the wheel, the edge may not be perfectly straight after Step 1. In this case straighten the edge by stroking a few times on a fine, fixed diamond stone. I use a 6" "fine" with a water based lubricant used to cool cutting tools in a machine shop. This slimy stuff makes the tool glide easily. It is not essential. (I have 11 gallons of the concentrated stuff (long story) and no machine shop and I am trying to find uses for it.)
Step 3. Pull the tool across a cast iron plate charged with XX micron diamond and lubed with WD 40 (or whatever).
Why it works: Diamond cuts like you can't believe unless you have tired it. And, only a small fraction of the bevel is being ground because of the hollow. When this part gets so wide that Step 3 takes too long, then revisit the wheel and grind this flat away.
As an illustration of how well diamond cuts, with a few minutes of grinding it is possible to flatten the hollow grind using 1 micron diamond even on a tool made from highly abrasion resistant 3V steel.
Notes: Maybe because of the scratch profile, or inclusion of carbon from the cast iron, the surface reflection from 1 micron diamond looks dull compared to 1 micron alumina. If a mirrored surface makes one feel better (I am doubting it will cut better) then 3 strokes on leather with the green chrome oxide stuff will do the trick.
There is one significant disadvantage to this approach. Unlike a water stone, the surface of the cast iron does not wear away. If you get the cast iron contaminated with coarse grits it is there forever, or until you get the plate surface ground again. Warning- do not store your 15 micron diamond next to the 1 micron.
