fitting dovetails question...
Bill Tindall, E.TN
>Yes, I know you are supposed to saw them perfect and fitting is unnecessary. At my skill level I can often do it if the situation is compressible poplar tails into rigid maple pins, for example, like on a typical drawer. But this trunk is oak into oak and this oak is not compressible. I might as well be trying to fit brass pins and tails. In fact, maybe I should be asking the infill plane makers!
Anyway, with great care, since they will be on a trunk corner for all to see, I have the pins and tails sawed and they are crisp........and in most cases a few thousandths of an inch from going together. In most cases I can just make out the remains of the scribe line on the pin top, so I am less than 0.010 from perfection.
Let me preface the questions by saying I have never had great success in diddling with pins and tails to make them fit. What once was nice crisp sawed pins and tails get rounded and out of shape as I attempt to remove material by various means.
Questions: 1.What is the best strategy for fitting- remove material from pins or tails? I think pins as they seem easier to get at with the wider spacing between them. 2. What is the best way to remove a few thousandths of an inch of material so the pieces will slip together. 3. In a row of 14 fairly closely spaced pins, what is the best way to locate some that are too big?
