Question on scraper sharpening
Bill Tindall, E.TN
>How does one tell when the edge is filed sufficiently to proceed with burnishing?
Re: Question on scraper sharpening
Robin Corell in Atascadero CA
>A well prepared scraper has a very slight curve to the edge so when filing you are removing the old burr and making the edge flat in preperation to raising the burr which will once again put a slight curve to the edge. The filing should not take more than a few strokes with a sharp file and I usually get better results moving the scraper across the file than using the file in a traditional manner. I always had dificulty in geting a good burr until I followed the directions I had read SO MANY times, and used a drop of oil when burnishing. To me this one little detail is the most important to having repeated success in preparing a scraper.
Robin
Denis Ch�nard, Orl�ans, Ont.
>Are you saying that you don't hone the edge and go straight from the file to the burnisher?
Just curious,
DC
Jim in VA
>I find that a bit of parafin wax (which I always have around for plane soles and saw blades) accomplishes the same as a drop of oil and is less messy.
ThomD
>Once the edge is sharp it is ready to burnish. The edge needs to be restored to a corner format full length, and as polished as possible/practical. I normally just touch the scraper to a belt sander. Sometimes one even gets the burr just from that. Or I draw file it, but that can get metal on my wood bench. I use the sandvick scraper and the thinest LV. I don't bother stoning them I go straight to burnish. One thing that helps with bunishing, or raising the edge a second time, is to pump the edge into a concave flex and burnish it in that condition. Shouldn't really be necesarry with the first go over. but sometimes I blow it and don't quite get the edge sharp and I can sometimes get the burnish I want if I pump it. I'm sure going through the whole half hour process with clean-up is better, but if I can get the trick down to 30 seconds I will get more work done than doing a perfect job, and by and large there isn't much advantage to a hyper scraper. It's not like the difference between a finish plane, and a FINISH PLANE!
