My Tabouret Table, A Project Review
Jim Shaver - Oakville, Ont
>Hi,
It�s been awhile since I posted some work, I recently finished a small project and thought I�d post it here.
A few months ago I took a hand sawing class with Chris Schwarz at a Woodcraft in Michigan. That class inspired me to go home and pick up my hand saws and make a project that involved these newly leant techniques. I wanted to blend these saw skills with some of the basics I had already been using with my other hand tools and complete a useful exercise-project.
As luck would have it Chris influenced me again, I had a copy of Woodworking Magazine with a small Tabouret table on the cover. I read the article inside and decided I would use this table design as my exercise-project to test out my new saw skills.
If you know Chris, you will know that no simple project or project that he writes about is simply about the plan, his writings incorporate interesting histories or technique elements and explanations that take his words from a level of instruction to a journey.
After reading the article I decided that I would also use this exercise to test out a Jeff Jewitt glazing technique I have been lingering over now for some time.
The new techniques for me in this project would be mortice and tenon joinery all by hand, dove tailed cross members and half lapped stretchers and corbels.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Hand cutting also all my rough lumber by hand, controlling my cuts to layout lines . The only power actually used was in ripping the rough stock and jointing and planning the stock to shape. I also did cut the table top on the band saw and made a leg detail on the feet that Darrell Peart explain in detail in his book �Greene and Greene furniture�.
Photobucket
Photobucket
I chose some quarter sawn white oak to make this table. The wood for the project came out of two boards, an 8/4 board provided the legs and a 5/4 board provided the table top and stretchers and corbels.
I followed much of the plan from Chris�s article with an exception, I added a foot detail I have made before using a simple jig and a straight cutter with a router. The details for making the jig and cutting the profile are well documented in Darrell Peart�s book
As mentioned the glazed Mission finish is one posted on Jeff Jewitt�s web site. The following were the steps I followed
Stain with TransTint Brown Mahogany diluted at 1 oz dye to 2 qt.* water
Apply one coat General Finishes SealACell Sealer.
Let dry one day and scuff sand with 320 grit
Apply Bartley Walnut Gel Stain. Wipe clean and let dry overnight.
Apply 2 coats General Finishes ArmRSeal Satin Finish.
Apply furniture wax and buff.
Here it is.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
I like the look, it�s a bit dark for my liking but it was a good exercise project that I was able to apply some of my newly learnt sawing skills to and also to develop a finish that I can improve on but like just the same.
A fun little project that taught me a lot, working with hand saws now has become a part of my process. Thanks Chris!
Thanks,
Jim
Re: My Tabouret Table, A Project Review
Parisian, VL
>Thanks for the great write up. You are an inspiration.
Victor in Hot and Humid Houston
Wiley Horne -- So. Calif.
>Jim,
Great story! And a handsome and very usable project too. Chris provided the immediate inspiration, but then you worked 3 or 4 new design items or techniques into this project on your own. I know you've been studying Greene & Greene for some time now. Those leg recesses are nice--do you think that they could be scored with a cutting gauge and cut with a fenced hand router? Or is that what you did?
I remember when Jeff Jewitt was recommending coats of thin shellac as a sealant for the Transtint dye rather than this new special sealant. At that time, he recommended to experiment and use as many coats of the shellac as required to control the lightness/darkness of the glaze and the pore penetration of the glaze and the wax. Did you feel that you had control of the glaze and were able to wipe it back to where you wanted?
Anyway, beautiful project, and thank you very much for not only sharing, but also making a great story out of it and tying so many different threads and inspirations together!
Wiley
Dan Clermont in Burnaby
>Nice Work Jim! Too bad you had to cover up those dovetails
Dan Clermont
Moses Yoder
Moses Yoder
>As usual Jim, an outstanding job. Thanks for the story and pics.
wilbur
>Very nice job, Jim!
If you were to do this again and try to lighten up the color, would you make adjustments to the mahogany dye application or the gel stain?
Actually, why did you dye and stain your table, instead of doing just one or the other?
As you can see, I'm a finishing neophyte. I pretty much stick with Waterlox, or nothing.
Patrick Gibbons, Somewhere in Texas
>Very nice table. I started building one for my sister, made a mistake, moved, packed it away, etc., etc. Hope to begin working on it again soon. Yours looks so nice it gives me impetus to accelerate my schedule and stop procrastinating. A really nice job. Thanks for sharing.
Turned out great!
Scott Burr in Ben Lomond, CA
>Very nice looking table. I like the darkness of the finish myself. Nice job on all the details as well.
>Thanks Wiley,
I can see you being able to do this with a router plane and some scoring tools, but I used a P&C router here.
I have been a long time fan of Jeff Jewitt's, I was familiar with the shellac sealer idea, I found no problem though with the products from General. Although the three pieces for the top came from a single board I was surprised how the centre board absorbed the Transtint over the other two boards. I should have cut the dye by another 50% I think, but it is what it is. The glazing process was simple, my first time trying it, since it was oil based I had some open time and no concerns.
Thanks,
Jim
>Hi wilbur,
The stain was the galze in the process, between the sealer coat and top coat, it never penetrates the wood.
Thanks for your kind thoughts,
Jim
Thanks Every One
>Thanks everyone,
The table is used as a side table with one of my Morris chairs. I am happy with the project.
Thanks,
Jim
Jennifer@Indy.USA
>Jim,I don't visit the handtool side very often but I sure am glad I did tonight! What a great little table. I love the detail in the legs. That really adds to this really sweet table. Fantastic photo essay!
Jen :)
