Veritas - Innovation in Tools
Norris A5-inspired smoother
Raney
>I have been lurking here for at least a few years now, but I post rather rarely... and the only posts I've made recently have been somewhat petulant. It was mentioned to me that perhaps I should take a bit more 'active' role in WC, so I shall try to do so.
As a first step to try to make up for it, here are some pics of what I've been working on for the past few weeks. My apologies to those who have already seen this on another forum I regularly post to.
The blade is a 3/16" Hock bedded at the classic 47.5 dsegrees. Infill is from a blank I bought a couple of years ago under the name "Burmese Blackwood". I am not at all familiar with the name, and I suspect it may go by various other names as well. Given the odor and surface, I think it is a safe bet that it is some sort of Dalbergia. If anyone has any information on the species, I'd be grateful
Re: Norris A5-inspired smoother
Nice work!
John in New Mexico
>I've got a sheet of 3/16" brass I keep meaning to make one of those out of! Only been waiting 10 years or so.
So how's the cut?
Stunning !
steve mackay
wilbur
>Excellent job, Raney! The thing that amazes me is the way you just toss out that "I've been working on [it] for the past few weeks." It takes me a few weeks just to get a board milled to size.
Jim in Burlington Ont.
Sweet
>Stunning plane. Be very carefull making tools can be a slippery slope.
Wiley Horne -- So. Calif.
>Raney,
What is particularly impressive to me is that the overstuffing looks to be right on the money, as does the dovetail join of the curved sole to the sidepieces.
Thanks a lot for posting this plane!
Wiley
Re: Nice work!
Raney
>It works quite well - I would say basically on par with my LN 4-1/2, as it is dimensionally quite similar, and weighs about the same (just a bit more). I don't know that there is much of a 'next level' of performance, a I think any good plane can be made to work as well with adequate tuning.
Re: Adjuster
barryvabeach
>Raney, it looks great, Is the adjuster an item you bought from someone or did you make it? Barry
Very nice. Thanks for sharing.
Parisian, VL
Re: Adjuster
Raney
>Barry,
It's the Ray Iles version that Joel sells (toolsforworkingwood.com)
I'm not much of a believer in the need for adjusters, but I wanted to try one out. Unfortunately, with the 'modern' cap irons (hock, LN, etc) the adjuster ends up much farther up the iron than ideal (thus the long shaft stretching above the tote). Ideally, the cap iron would be altered to move the screw further toward the edge so the adjuster could operate lower on the blade.
I am almost certainly going to remove the adjsuter, as I really don't see much need for one in a smoother. Having one on hand, though, the temptation to put it in to play with it for a while was too great.
I am considering using a depth-only adjuster, which would be pretty easy and inexpensive to make from off-the-shelf hardware, on a panel plane. I do appreciate the depth control somewhat, and would use it if available. The lateral adjustment (and pretty much every lateral adjust mechanism I've ever used) is pretty worthless as far as I'm concerned. The cost and difficulty of including lateral adjust seems to me a gross waste of effort and resources.
...but I wanted to have it in a plane for a while to confirm this :)
I have a bunch of questions...
Scott Burr in Ben Lomond, CA
>First off, very nice job!
Was this plane from a kit or did you construct it from scratch?
Did you make the adjuster?
Well, not a bunch of questions I guess.
Thanks for sharing it!
Re: I have a bunch of questions...
Raney
>Hi scott,
Thanks. The plane was from scratch. Sourced parts were a Hock blade/cap iron and a Ray Iles adjuster from Joel at TFWW.
I have a bunch more questions...
>Thank you!
How did you bend the sides into their shape?
Heck,how did you cut out all the parts?
I can see ditching the Norris Adjuster, never worked worth a sh#t for me!
Cheers!
couple more answers...
Raney
>Scott,
Everything was cut with a hacksaw. After the pins are cut in the sides, and secondaruy dovetail bevels filed, the sides are bent using a simple clamping block in a vise:
Photobucket
Just 8/4 stock with a curve cut on the bandsaw. The curve needs to be a good bit tighter than the final desired curve to compensate for springback, but overall it's actually a pretty forgiving and simple process...
hope that helps
Yes, It helps a lot. Thanks!
