My bech continued...
Corey Megal
>Here are a few more pictures for those that asked for them. I tried to show the details of the work holding a bit more. You can see the tail vice and how I had to offset the dog to line up with the dog holes in the bench. When I drilled the dog holes (before the final glue up) I drilled them from the bottom with a 1" bit to a depth of about 2", then drilled the 3/4" dog holes from the top. The reason I did this was that I had read the holdfasts may not hold as well in a full 4" thick top. Also, I use the Lee Valley bench dogs and they are a little short for a 4" top, the extra clearance at the bottom helps me push them up. I've thought about lengthening them with a bolt, but so far it hasn't bothered me enough.
Thanks for the kind words.
Corey
