200+ woodworking book reviews
Scratching my head
Scratching my head
Scratching my head
>I have encountered twist auger bits that have drilled through or past nails and has caused damage to the tip, compressing the metal and making the end a bit smaller so it can't cut a decent hole.
Sometimes this can be repaired, sometimes not, I have bent a few back but sometimes the damage is too great.
This is different, recently I bought (at a reasonable price) a Jennings style (the spurs are different) Number 3. Now I owned an Irwin in that size a number of years ago and sold it. I had not seen a 3/16 double twist until a couple of weeks ago when I bought this one.
I sharpened it up, straightened it out and was waiting for the opportunity to use it other than tests, it seemed to drill a nice hole very fast.
So I was about to use it when I did a test hole to make sure the small peg would fit, and it didn't, the hole was too big. The peg was 3/16".
I checked the shank and twist and they are 3/16" but the tip is larger and drills almost a 1/4" hole. I know the universe is expanding but I don't think that applies.
I am wondering if the thin nature of the bit allowed for it to untwist somehow and get bigger? Because of the spurs I can't just file off the excess, I would loose the thin spurs. And it looks like it has spread equally on both sides of the thread (softwood) pivot.
I am wondering how would be the best way to get it back, so I can use this bit? I do have a spoon auger this size but I would like to put the double twist into working condition.
Any suggestions?
Stephen
Re: Scratching my head
Marv....... Northern California Lake Co.
>Stephen,
Perhaps the center point is off center causing only one side to cut.
It that isn't the problem, to make it become the right size again, turn it in a 3/16 hole that is drilled in a piece of steel, but turn it backwards.
Marv
with what?
Robin Corell in Atascadero CA
>sounds like it may be a bit from a hollow chisel mortice set. My 1916 vintage machine uses a bit that measures .3" across the ways for the 5/16 chisel but I think the flutes measure 1/4"diameter.
Robin
Re: with what?
>Robin,
It is a tanged bit so it is meant for a bitstock, here is a picture, the little bit at the bottom.
Stephen
Re: with what?
>I think most mortise machines use straight shanks and bushings to secure the bits but I do remember reading about one that had an adapter for using square tappered bits. The owner was never sure if it was stock or modified. You would be more knowledgeable than I to know if any of the old crank powered beam boring machines came equiped to use with holow chisels or if they were ever equiped to use tapered square bits.
In my mind this would be the only other use for such a bit as the machine would have kept the bit boring straight and not needed flutes to be the same size to help guide the bit. this would have let the bit run cooler not that I have had much of a problem with hot bits in a brace. Outside of this it is an odd thing as I can't imagine the force needed to unwind the flutes of a bit ever being applied while drilling anything wth a brace.
Robin
Difficult little bit to photograph
>I tried several times and ended up putting it through a piece of paper to get a good pic of the end.
It is a bit intended for a bitstock, a brace, and it has somehow gotten bigger that it was originally intended, it is a number 3, indicating 3/16".
I hope this pic helps, and the expansion seems equal on both sides of the pivot.
Stephen
Re: Difficult little bit to photograph
>Stephen,
The point is off center causing one side to do most of the cuting.
Marv
paul womack
>Most augers cut slightly larger than the flutes; this is for the same reason one puts set on a saw.
BugBear
Yeah but......
>Not so much as to drill a hole 1/16" bigger in diameter. Stephen says it drills a 1/4" hole.
Perhaps the wrong size is stamped on the shank.
Marv
Re: Yeah but......
>Nope, the shank and twist is 3/16" and the cutting edge is slightly under 1/4", so it is a problem with this particular bit.
My other small bits drill the proper size, their spurs no wider than the rest of the drill.
Stephen
Stephen....use your other drills, problem solved.
As well you should, to a point...
Scott Burr in Ben Lomond, CA
>Most know that Jennings and some Irwins bits drill a hole fore the specified hole for the hardware going through the whole. I.E. a bit (ha ha ha ) larger than the whole size it's self. Otherwise you'd be looking at a true doweling bit. I.E. a 3/8 bit will drill a bit over that amount.
Hi!
Marv, you were right and...
>This small bit had been untwisted, I did some careful measurements (which I seldom do) and the center was off to one side. This little bit had some bends and twists that contributed to the problem. The center threaded spur was off center and unusual cant to the head of the drill bit.
This bit is 3/16" and is so marked like all of the other bits it is intended to drill a hole exactly that size hence the stamp 3.
The untwisting of the bit and a bend in the top put one side lower than the other so the side was wider.
I carefully used my new brass hammer to get the bit a bit straighter then used a small metal working vice to bend the lower spur back up. I tapped the sides got everything straight as I could and used a pair of pliers to squeeze the wide parts together.
That took a few attempts and some real squeezing. I didn't use my small vice as the faces leaves marks. I then dressed it up with a small WARDS auger file I have, touched it up, dressed the sides and it works just fine and drills a perfect (as near as I can tell) 3/16" hole. Because it has no down cutting spurs, the entry hole leaves something to be desired, but it is a good small hole. Well worth the effort to have a small twist auger bit that drills a proper hole.
Stephen
Re: Marv, you were right and...
paul womack
As I understand it, only "dowel bits" are intended to drill to exact size; all other auger markings are nominal.
A bit like plough plane blades.
BugBear
>'As I understand it, only "dowel bits" are intended to drill to exact size; all other auger markings are nominal.'
I believe 'dowel bits' are shorter twist auger bits, about half the length of ordinary twist augers.
Stephen
Stephen....one might think....
>that an auger bit such as the one you just miraculously repaired would just screw itself into the wood like a screw instead of making a hole. The auger bit doesn't have a web up the center like say a metal cutting drill bit with flutes spiraling up the sides. Am I right about that?
Without a web up the center, it's easy to see how an auger bit can become deformed if it binds in the wood. It could happen going in and or coming out. It would more likely bind on the way out due to the unraveling effect making it tighter in the hole which appears to have happened to your drill. As it unravels it gets larger but oval shaped.
It doesn't seem to be the best design for a drill bit. We usually see that design on the really long bits like for drilling through large beams. However those bits are much larger than the one you are dealing with. The larger bids are less apt to unravel so to speak because of there being more metal.
Having a drillpress next to where I do most of my drilling, I normally will use a metal cutting drill even for wood as long as I don't need an extra deep hole. Works great for dowels.
Marv
Well, Marv...
>I for one don't want to rethink history or what could have been or what they would have used if they would have had it, that is pointless. I am just talking about this bit, nothing personal, and that ad hominem comment I think was uncalled for.
This is all about that nicker nib thing isn't it?
Stephen
I'm baffled......
>I can't imagine anything I said that was offensive in any way.
Perhaps I need to rethink spending my time trying to be constructive and helpful in some minute way.
ad hominem comment? What the hell ya talk'n about? There was nothing argumentative about anything in my post.
Please explain why you are offended...Jeeeez
Marv
Hey wait a minute....
Wiley Horne -- So. Calif.
>Stephen,
C'mon. Time for high fives and ten low. Smell the roses. You and Marv just worked something out, that I for one found fascinating. I never heard of an auger unwinding, course there's plenty of things I never heard of. Anyway, it worked out very positively!
I suggest your re-reading Marv's post. I didn't see any hook in it, even remotely. In fact, I thought it was interesting also.
Wiley
I appologize
>knee jerk reaction to the flack I get from Marv and Scott.
Guess I will take some time off to cool down.
Again I appologize.
Stephen Shepherd
appology accepted.....
>Stephen,
I appologize also for not being clear when joking around and being serious. Too often it's difficult to read someone's post and know the difference.
When you posted your hand sketch of your knicker nib tool, I and others took it as a joke and responded in kind. I took your sketch as a follow up to our joking about nibs in the chatroom. I guess you interpreted my response as flack but I meant it as a joke. Looks like we had a failure to communicate.
The problem comes about in these forums because we are trying to communicate with a number of things missing. We don't have eye contact or facial expressions or other body language or timing of speech. Usually we are trying to keep our messages as short as possible. Consequently we don't type the words that would indentify all those aspects that normally help us communcate our feelings as we do when we are face to face. It isn't always this way but often times it is. Sometimes it's just a matter of using the wrong word or words when trying to express ourselves. This can easily result in injecting the wrong tone in our message.
Maybe we need a universal code word to let people know when we are kidding or joking around. I tend to joke around a lot and don't think of it as "flack". We need to keep these things in mind and not be so anxious to pounce. We need to have a thicker skin and give the other person the benifit of the doubt and ask questions first. I need to apply all this good stuff to myself, but I'm sure that in a short time I'll forget about all this and continue on doing what I'm in a habit of doing, as will everyone else. With that in mind, lets shake virtual hands and try to be more understanding.
I enjoy reading your posts and have learned a lot from the various subjects you have expounded on and your answers to questions from others.
Respectfully,
Marv
Rx: WoodCentral forum survival kit
wilbur
>Take these, sprinkle liberally throughout post as needed.
Or, the pre-nose job version:
