More tool cabinet progress photos
Dominic Greco in Richboro PA
>Hello Everyone,
Here are some more photos showing where I stand with my tool cabinet project.
I finished the glue up a couple weeks ago, then installed hardwood inserts at the mitered corners. This is a trick I picked up from an old copy of "Woodsmith". It helps to make the mitered corners look cleaner. After I completed that, I built a dovetail spline jig using an idea I saw in "Woodworking with the Router" by Bill Hylton.
After I completed the jig, I cut the dovetail splines, then I milled up some walnut for the dovetail "keys". These were then installed with glue, allowed to dry, flush cut with a saw, then planed flush with a LA block plane.
I also made up a jig to help me get the drilling for the shelf support pegs as perfectly spaced as possible. I just used a piece of 1/4" hardboard and cut it to the width and height of the piece where the holes were to be drilled. I made some reference marks to make sure I always kept the correct orientation, and then drilled holes in it with the correct spacing. I then just clamped it in place and used a drill bit with a depth stop. If you notice, the side where the plane till will be (the side without the shelves installed) also received a set of holes. This is just in case I find that the plane till is not working out and that I want a cabinet totally comprised of shelves.
I milled up the lumber for the drawers last night and will hopefully be able to finish them this weekend. After that, I'm on to working on the doors.
See ya around,
Dominic
