Re: The real answer
ThomD
>I ave have made things just like that, and what they were for was to transfer blind measurements. I used mine mostly for boatbuilding. But a house example that I am just making up, but it will give the idea would be imagine putting something in the way of clading on the structure. I will use drywall if not historically accurate. You put the boat over everything including window openings. Today you would establish the opening by using a trim cutter or router with a cartridge bearing that would run on the window framing. But another way is to rough out the opening within a few inches all around then take the tuning fork so one leg rubs the framing and the other allows you to draw a line. This will allow you to precisely outline the frame from the back side to the front and then cut it in with a saw.
The kind of thing in boatbuilding is if I put down a 1/8" plywood deck, then trim it to within 3 inches, then I would run my line showing exactly where the side of the shear is, but on top of the plywood, then I could vac bag down some balsa core to that line without wasting materials. I need the run-wild to have a place to glue down the vac bag. later I can trim it either to the scribebd line, or to just blow it out with a router. In that case the main advantage is economy, knowing where to stop using an expensive material.
However given how precise that thing is it would be for doing open skirtboards (OSs) onstaircases. Today the way we do it is build a 2x staircasse. Then come to the outside of the staircase and run an OS board accross all the open ends and as low as required to give the trim we want. Then we take that gage and fit it over the OS level with the tread allowing us to transfer each tread to the outside surface of the OS. We do the same with the kickboards, which may be vertical or sloped. That line also transfers to the outside, however it needs to be advanced by the thickness of the OS, which ought to be the width of the arm on the gage. Then we un-tack the OS, and saw the tread lines at 90 flush, and the kick lines with miters. Then we refit the OS, and permanently attach, then your decorative kicks are flipped over so that the newly formed 45s allow scribbing the outside of the miter on the kick and the inside is scribbed or butts at 90 on the skirt at the wall thereby allowing perfect fits without any math whatsoever.
