Re: the real answer
ThomD
>That modification always looked like a pretty big hole to me, in the 5/16" range. For that I would want a drill press, and some center drills a few to move up from the initial dimple to the 1/4" final you would need to go 5/16 coarse. You need some serious hold downs.
Hill used a rebate plane for that, I think, partly because in cutting the gains at the stem you need to be able to not only strike the bevel, but work down through the plies so that where the ply attaches to the stem it is flush. Of course you can do a work arounds on that with saws and stuff.
In the book he is pictured with the block plane modified, and I think you could get away with a pretty small hole there as has been suggested or even without taping it at all. Not sure what is shown in the movie.
Three other options from an endless list:
- If your block plane uses a thumb screw, like the LV, build a jig that clamps off that screw and produces the incidence reference you want.
- There are a variety of rebate planes that mount fences that can be easily adapted to this task, they already have a hole and a set-screw, just replace the fence with an incidence one.
- take a few minute and make a wooden one, then mortice the incidence device into the wooden body.
Remember, Hill is a pro who built from a fixed list of boats. If you are making boats of widely different designs, as often amateurs do, the whole jig he makes up takes more time than just shooting the bevel by eye and doing a little fitting.
