Re: Anvil Pics 2 of 2
Alan DuBoff
>Todd wrote:
"I always had my anvil so that the horn faced toward my my right as I faced it...I know not correct but just seemed more natural to me. I think I read how 'smiths in Europe do it, don't know....."
Ok, I will admit to you that I had been using my anvil with the horn on the right, before I met Scott Thomas, the smith at Ardenwood Historical Farm. One of the things that Scott taught me was to never use gloves in the smithy, unless one is stamping/cutting over a large piece of hot steel, in that case it's nice to have some protection on my left hand. Some smiths use gloves while they forge, that might make a difference. I hate it.
In regards to not wearing a glove, this means that you will typically need a full slack tub, so that you can easily cool the metal, often dunking one's entire arm into the tub, and keeping the hot iron out of the water, so one can cool the iron they hold, but leave the iron being worked hot. I'm explaining that for others, I know you know that Todd...in that setup, since I hammer with my right hand, it makes sense to have the slack tub on the left side of the anvil, so it is between the forge and anvil. Really depends on the setup also, Scott places his anvil opposite the forge, with the slack tub on the right of the forge, but it is similar to how I described in regards to the slack tub on the left side of the anvil, being that he also forges with his right arm.
The other annoying thing I find about the horn on the right side is that I like to feed iron up from the bottom side of the horn, so that as you're scrolling, you are hammering on the top and feeding it, using the top portion of the horn to leverage/control the scroll as you create it. This could be me, but I don't care for doing that with my left arm between me and the anvil, I seem to have a lot more flexibility when that arm is on the outside of my body, not pinched in between my body and the anvil.
These are the primary reason I like to have the horn on the left side, but before I started scrolling like that, it didn't bother me as much.
I like the front edge of the anvil, near the horn to have a sharp, crisp corner, and along the front as well, since I will work corners that are 90 degrees there, and draw metal out. But I like the back edge just so slightly rounded as I will taper and other stuff on the back near the horn. I have been taught to draw everything out square, even if it will be round, and I have a smithy friend that doesn't subscribe to that theory, but I think it helps keep things uniform, speaking for myself.
Maybe some of this will be useful to others, I don't know...
